    Duet WiFi board open circuit on hotend
    • duncan-rtfmundefined
      duncan-rtfm
      My Duet Wifi board seems to work brilliantly. Stepper motors move as expected, homing works, end stops work. Everything moves almost silently. Couldn't be happier.
      HOWEVER, no matter what I do I get an "open circuit" error whenever I connect the hotend wiring. I've bought and tried three different hotend/thermister sets. Still the same error. In frustration I bought another board (a Maestro) and wired that one up - and the hotend works wonderfully. Really impressed. Without touching the wiring on the printer itself, I wired up the WiFi board (power and hotend) and the same issue - "open circuit".
      Any suggestions?
      Regards
        Please post your config.g file and let us know what thermistor you are using.
          duncan-rtfm
          Here's my config.g file, together with a pic of the bag the thermister came in.
          config.g
            Here's the problem, in config.g:
            M305 P0 T9880 B4185 R4700
            Change to: M305 P0 T100000 B3950
            Similarly for the M305 P1 command. The B3950 is just a guess because the bag doesn't give the B value.
