    Duet 2 Wifi-smart effector pins
    • Tomsonundefined
      Tomson
      Hi
      Any one know what exactly pins i need to duet and smart effector ?
      I bought unfinished delta project (a lad making it sadly passed away and got it from his wife)
      I got plugs but not all the pins so im going to order pins and complete printer
      Thanks
      Ok got it 🙂
      So i got all shells and few wurth pins left
      For smart effector i need molex microfit 3 female pins 🙂
      Any one know if duet sells bags of wurth pins on its own ?
      • Tomsonundefined
        Tomson
        So it seams to molex micro fit type plugs for smart effector are a wurth electronics and molex pins dont match ☹
          dc42 administrators @Tomson
          @Tomson said in Duet 2 Wifi-smart effector pins:
          That's right. Use shells and crimp pins from the same manufacturer, Molex or Wurth. The 8-pin connector is Molex KK or compatible, the 6-pin connector is Molex Microfit 3.
          • Tomsonundefined
            Tomson
            @dc42 I bought wurth pins for molex kk style shells as was have a few pins in wurth bag, thats work great together
            but for 6 pin and 2 pins i bought molex microfit pins and dosent match
            after ripping my hairs off my head id notice that black shells got WE writings so i assume i got all shells from wurth
            By the way its ur delta design printer 🙂
            • Tomsonundefined
              Tomson
              Ok so after looking at cad model and drawings of connector pins should be compatible
              So verry carefully did crimp them again and it works, cheapo crimping tool i think its to blame
              U can pull out crimped cable by loads of force destroying pins btw
              So another question
              I got screened cables so why not to make a use of it ?
              Since duet dont have dedicated point for it where will be best point to connect screen ?
              Frame ?
                Frame, or a ground pin on the Duet.
