    no connection
    • A Former User?
      A Former User
      help appreciated
      status:
      1. verified exact name and password by connecting my phone to it
      2. blue led is flashing
      3. M589: Bad or missing parameter<LF>ok<LF>WiFi reported error: Failed while trying to connect to eli33<LF>WiFi
        module is idle<LF>
      4. M552 S0, M552 S1, M552S2:
        ok<LF>WiFi reported error: Failed while trying to connect to eli33<LF>WiFi module is idle<LF>
        WiFi reported error: Failed while trying to connect to eli33<LF>WiFi module is idle<LF>ok<LF>WiFi reported error:
      do I need to do enter ip address or something? where?
      anything wrong in the sd card?
      • PaulHewundefined
        PaulHew
        Have you done these steps?
        https://duet3d.dozuki.com/Wiki/Step_by_step_guide
        It has a fixed ip address from build IIRC.
        HTH
        Paul.
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
          droftarts administrators
          @ooly What are you using to set up your Duet? We recommend using YAT, because if you use other serial comms tools, they convert all text to upper case, so SSID password may be wrong (though I note your access point is lower case 'eli33'). Also, check that the access point you specified is 2.4GHz, as 5GHz is not supported. You can see the stored access points by sending M587.
          How your router/access point is set up (encryption, and whether Wifi connected devices are reachable from the rest of the network) may effect connectivity to the web control.
          @PaulHew Maestro and Ethernet have fixed ip, Duet is DHCP from new.
          • A Former User?
            A Former User
            Paul - thanks. will try to follow these steps.
            droftarts - thanks as well. M587 is answered by "failed to retrieve network list". any idea?
            • A Former User?
              A Former User
              where can I download all the files for sd card version 2.02 rtos ? I may have to replace corrupted card
              thanks
                droftarts administrators @A Former User
                @ooly said in no connection:
                thanks
                https://github.com/T3P3/Duet/tree/master/Duet2/SD Card Contents
                • A Former User?
                  A Former User
                  thanks, droftarts.
