    Configure 4 Pins for PWM Output (Analog Voltage) On Maestro
    pwm control analog output
    • 3ddevilundefined
      3ddevil
      Hi @dc42
      If I want to create 4X Analog voltage controllers leaving Fan0 and Heaters 0+1 alone, we have come up with this list, which seems to max out our native controller access:
      Fan 1
      Fan 2
      Heater 2
      Servo (Z Bed Probe)
      According to the documentation here, it is possible to turn these outputs into controllable PWM outputs using https://duet3d.dozuki.com/Wiki/Gcode#Section_M42_Switch_I_O_pin is that correct?
      The heater needs to be disabled and not referenced by a tool "using M307 H# A-1 C-1 D-1 to make the pin available." Is there any such requirement for the fans/servo?
      Finally, if buffered correctly (F=10KHz) and routed into a proper RC buffer can we expect to an analog output from 0-3.3V for Servo and 0-Vin for Heater and 0-Fan Voltage Set? Can you confirm this is possible?
      are there any more outputs / alternative pins natively supported by the Maestro or is that all we can do with the chip as currently routed?
      3ddevilundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • 3ddevilundefined
        3ddevil @3ddevil
        So this is solved for the Servo output, it worked exactly as expected. Quite amazing!
          dc42 administrators @3ddevil
          @3ddevil said in Configure 4 Pins for PWM Output (Analog Voltage) On Maestro:
          Yes, see https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins.
          If using a heater or fan output, you would need to add a pullup resistor to +3.3V if you want a 0 to 3.3V output.
          The available pins on the Maestro are listed at https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins. Only the heater, fan, and Z probe control/servo pins are PWM-capable.
