    Error:short-to-ground/over temp shutdown reported by driver 0
    • AlexTheGreatundefined
      AlexTheGreat
      So I'm new to this kind of stuff and I'm having a little trouble getting everything up and running. The wiring was easy, I've done that lots before. The configuration not so much apparently. I could use some help from someone who is far more qualified than me. I'll include all the info I have below. If any more is needed don't hesitate to let me know. I just want to get printing again!!
      So here is what I'm running:
      Firmware Name: RepRapFirmware for Duet 2 WiFi
      Firmware Version: 2.03 (2019-06-13b2)
      WiFi Server Version: 1.23
      Web Interface Version: 1.22.6
      All the wiring looks good to me, nothing is on the board. In the web interface, I can move the X, Y, and Z motors up and down. I can heat the bed and hot end, I can even extrude. So I can't for the life of me figure out what this error code is popping up for!
      Error
      Over and over again...
      *M122
      Error: short-to-ground reported by driver(s) 0
      Error: over temperature shutdown reported by driver(s) 0
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-956GU-DGMSN-6JKF0-3S46N-KVQHG
      Used output buffers: 4 of 24 (9 max)
      Static ram: 25680
      Dynamic ram: 93688 of which 0 recycled
      Exception stack ram used: 268
      Never used ram: 11436
      Tasks: NETWORK(ready,652) HEAT(blocked,1236) MAIN(running,3780) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:07:07 ago, cause: power up
      Last software reset at 2019-10-02 19:03, reason: User, spinning module GCodes, available RAM 11352 bytes (slot 3)
      Error status: 0
      Free file entries: 10
      SD card longest block write time: 3.4ms, max retries 0
      MCU temperature: min 20.1, current 38.4, max 38.6
      Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: temperature-shutdown! short-to-ground standstill, SG min/max not available
      Date/time: 2019-10-02 19:55:53
      Cache data hit count 1697445996
      Slowest loop: 4.88ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 40.56ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.23
        WiFi MAC address dc:4f:22:6e:6e:fc
        WiFi Vcc 3.36, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 22888
        WiFi IP address 192.168.0.17
        WiFi signal strength -46dBm, reconnections 0, sleep mode modem
        Socket states: 0 0 0 0 0 0 0 0*
      • 3ddevilundefined
        3ddevil
        I am not certain, but there are two possibilities I am aware of. I could also be totally off base as I'm not an expert on the wifi - but reported errors are not normally a fluke and usually mean wiring harness issues, overheating, or a damaged driver.
        1. overtemperature warnings on motor drivers may be a subset of 'short to ground' which is the most general kind of warning on the maestro. Perhaps it's just a temperature fault which is reported on the wifi
        2. your X axis (drive 0) can be moving just fine 99% of the time but shutting down due to overheating. Usually it's quite an audible click sound, the time off would be 100-1000s of milliseconds and a print would fail due to skips.
        Follow up:
        1. see if the driver is actually hot - measure indirectly, the temps could be over the boiling point!
        2. look for actual shorts
        3. try lower current, in case it is excessive
        4. if these fail, need to disconnect everything else to look for signal crosstalk
        AlexTheGreatundefined 1 Reply Last reply Reply Quote 0
          AlexTheGreat @3ddevil
          @3ddevil The X axis has since stopped working completely. I'm thinking it's a blown driver. What could I have done that blew the driver?
          Along with the board install I put on a E3D V6 hot end and BLTouch. Following all the installation guides. Any help or tips are appreciated.
            Either there is a short in the wiring to that motor, or the driver has blown. So check the wiring very carefully, and if you don't find a problem, try connecting a different motor and cable to that driver output. If the problem persists when using a different motor and cable, please ask your supplier to replace the Duet under warranty. Unfortunately, a small proportion of stepper driver chips fail within the first few hours of use.
            • kostasbmwundefined
              kostasbmw
              today i transfered my duet to a new corexy build and before i go on i wanted to test the movement..after connecting i had movement but in the wrong way...so i sent a m564 to check each motor separately...Z all ok disconected z wiring plug in X movement but i get the short to ground driver 0 error.....unplugged everything and click on x to move i get the same message.....is that normal?????note that i running the 2.04 firmware
                dc42 administrators @kostasbmw
                @kostasbmw said in Error:short-to-ground/over temp shutdown reported by driver 0:
                Please start a new thread and include your config.g file in your post.
                  kostasbmw
                  ok
