    Connecting to Yat!!!
    • wayne thorntonundefined
      wayne thornton
      Hey ! Well I got some time to work on this Printer once again. Its been a wile and even the rep rap config, has changed. So I wonted to change the config, and start fresh. So why wont Yat find Duet WiFi ?????
        Gonna need a lot more information to give any valuable insight.
        Mac or PC? Are the drivers installed? Try a different port. Try a different cable known good for data. Try a different computer. Try different software like Pronterface.
        wayne thorntonundefined 3 Replies Last reply Reply Quote 0
          wayne thornton @Phaedrux
          @Phaedrux ok ill try all of it
            @Phaedrux ok I have 3 new 2.0 usb to micro, I put it on a new Dell cpu, and down loaded the port updates. Whats pronterface would this work better than yat? can i get a link? Why is Yat not working?????
              @Phaedrux i put it on a new cpu new cord and new yat new config, ill try pronterface but whats the diff if its not responding to yat. Ill be in this Wednesday night < Im thinging its an expensive boat anchor.
                When you plug it into the USB does windows make the device connected sound?
                What LEDs light up on the Duet?
                Proterface is just another terminal software. Just trying to eliminate YAT as a variable.
                  droftarts administrators
                  Work through this guide, let us know what is and is not working: https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
