Configure Z stepper for Y?
I actually have a dual Y motor setup and a single Z
Can I configure the duet wifi 2 to use the dual z stepper to power the Y's instead?
so swap the Z for Y
is that possible?
Thanks!
Yes this is possible. You'll have to redefine your motor to axis bindings.
The two Z motor connectors are wired in series so both motors will get the same current, but their voltage will be halved. If you only have 1 extruder, you could use the second E axis as the second Y axis instead of the dual Z connector.
Either way, you'll need to use M584. https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
See this post as an example of the command: https://forum.duet3d.com/topic/12209/y-axis-endstop-always-triggered-on-maestro/5
Thanks for the info. I will check out the links!
