E?_ENDSTOP, Laser and rotary filament sensors, motor enable ?
  • Hi, new duet2ethernet user here. I jumped the gun and decided to replace existing 8bit marlin with duet2 ethernet board. I have most of the stuff working correctly but I have few questions that I could not figure out googling / searching forum / searching duet3d wiki so here I am on forum. For start, it is Duet2Eth board, no extension, running "First official RRF3 beta"
    M115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0beta10 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-09-12b1
    I know it's beta and that documentation is not up2date but I went trough release notes and basic stuff is working (2 extruders, 3 axes, 3 end switches, bltouch and paneldue).
    now the questions 😄
    • E0_endstop, E1_endstop -> what is the intended purpose for these? Some crude microswitch based filament runout detection sensor or ?
    • I have "PRUSA Laser filament sensor", is there a way to connect and use it? (never used it, sitting in my drawer, have not even checked on what principle it works)
    • I have bunch of rotary encoder based filament sensors (600 or 1200 or more steps rotary encoder, two rubber disks, filament go trough it and encoder rotates as filament goes trough). Similar I use on my smoothieware based printer where the output of the encoder smoothieware compares with the expected extruded length and if mismatched error is reported
    • is there "enable" pin for the motor driver exposed somewhere? (have not checked the schematic and pcb design files yet, have no issue soldering small stuff, even replacing the SAM would not be a problem). The reason is that I would like to "break" my axes to a degree when motor drivers are disabled or printer is turned off. I normally do this by having a relay short the motor coils when unpowered and I power it from the enable signal (trough transistor of course) so when drivers are enabled relay "release" the motors, but when enable is off the relay short motors so they resist movement (for e.g. enough for a belt driven Z bed not the slam down but to decend slowly when you turn printer off). If I can't get to enable signal I'll connect relay to VIN but enable signal would be better choice.
    thanks
  • I'm not familiar with RRF3 yet, but can give you some answers.
  • Thanks a million! I started with 3.0b10 as I'm 10000% new to duet and this printer conversion is not too important if it's going to work in 2 days or 2 weeks or 2 months so idea is - better start with the latest version 😄 no matter if it's unstable.
    I am running octoprint plugin with a switch on my non-smoothie printers and that works ok but I love the encoder thing that I have on smoothie. I had no clue prusa sensor is i2c, that's a weird decision taking into account how noisy environment this is supposed to be working in ?!?!!
    This magnetic rotary sensor works 100% identical to my rotary encoder (I use only A pin from the ABI output of rotary encoder) and the rest of the monitoring seems to work exactly / similarly as with smoothieware so ideal 🙂 thanks for the info 🙂 I'll go trough that forum section now.
    I found on schematic that ?_step, ?_dir and ?_en are exposed to test points TP1-TP5, this is awesome I can connect each motor to it's own enable 😄 just need to make small daugterpcb to go on to these test points 😄
  • @smece said in E?_ENDSTOP, Laser and rotary filament sensors, motor enable ?:
    I found on schematic that ?_step, ?_dir and ?_en are exposed to test points TP1-TP5, this is awesome I can connect each motor to it's own enable just need to make small daugterpcb to go on to these test points
    Ah! Test points. I forgot about those. The Duet WiFi I have is a prototype/beta version (white PCB) and doesn't have test points. Glad the current version can satisfy your requirements!
  • Yes, test points are perfect :). I originally, on the shared images seen "do not touch these" so ignored them and since they are 3 per driver (and not at least 4) I assumed they are probbly for current measurement or something TMC related; but schematic shows it's exactly what I need. I just pushed question here before looking at schematic.
    There is a M591 option to configure a pulsed filament monitor, which should work with your monitors based on rotary encoders.
    Do not connect to those test points. The "enable" signals on them are actually SPI chip select signals. Additional driver modules should be connected to the expansion connector.
  • @dc42 said in E?_ENDSTOP, Laser and rotary filament sensors, motor enable ?:
    found it, thanks, will be testing it shortly 🙂 but looks like all the cool options are supported so /me happy
    Yes, I noticed doing a further review, the ENABLE signal I need is the ENN net found on expansion port pin 28, so even easier to access 😄
    I do have other unrelated question, if you know, why is IPD036N04L driven with 3v3 directly without any driver. For 5V system the driver would really not be needed but driven with 3v3 Rds is 8mR (compared to 3.5mR for 5V) ... it will of course work but even expensive isolated tlp250 is $1 in small quantities, I doubt it would affect price of the board in any way?
    Check the schematic again. There is a 74HCT02 to level shift the signals from 3.3V to 5V before they reach the heater mosfets.
    😄 😄 😄 😄 it's on the same page, how the hack did I miss this .. it even has the explanation why it's oring inputs with 3v3 input 😄 many thanks!
    btw, thanks big time for all the leds on the board, especially the endstop ones!!!! saved me probably hours of debugging yesterday
    That's the first positive comment I've ever seen about endstop LEDs! We've left them off later boards (Duet Maestro and Duet 3), because (a) users get confused that when using the recommended NC endstop switches, they are on when the endstop is not triggered and off when it is, and (b) the additional sink current required by the LEDs is problematic for some optical and Hall endstop switches.
  • I'm using mechanical switches on this conversion (ender5) and had a weird bug, connector was purely crimped so was losing connection ... jiggle wires a bit and you see led flashing - doing that trough g-code, checking if it's triggered or not with flaky connection don't work 😄 leds are cool 🙂 ... I do like the PLC way (you have separate IO for the led so cpu writes to led what it reads from switch) but this just saved me min 1h of debugging 😄 ...
    as for the "problem for some sensors" ... I'd say it's a problem with those sensors 😄
    and this board is cold!!! the hottest point on the board is the ETH driver 😄 😄 😄 ... have not used this drivers before they don't go over 40C no matter what I do to them 😄 .. seems like no active cooling is required at all 🙂
