SOLVED Error: Calibration failed, computed corrections: nan nan nan nan
  • Hi,
    I'm trying to use the manual bed levelling assistant but I'm getting this error:
    "Calibration failed, computed corrections: nan nan nan nan"
    does anyone have this problem with the last firmware - 2.03 (2019-06-13b2)?
    This is my code:
    config.g
    ; Manual Bed leveling assistant prerequisite
    M671 X35:275:275:275 Y35:35:275:35 P0.2     ; adjusting screws at front left (35,35), front right (275,35), rear right (275,275) and rear left (275,35), thread pitch 0.2mm
    bed.g
    G28  ; home all axes
    G30 P0 X35 Y35 H0 Z-99999
    G30 P1 X275 Y275 H0 Z-99999
    G30 P2 X275 Y35 H0 Z-99999
    G30 P3 X35 Y275 H0 Z-99999 S4
    Changing the last S4 from bed.g to S-1 I get
    G32 bed probe heights: -0.500 -0.100 -0.450 -0.500, mean -0.387, deviation from mean 0.167
    The last X and Y coordinates in your M675 command are wrong. This has made 2 of your leadscrew coordinates equal, resulting in a singularity when the matrix is solved for the corrections needed.
  • @dc42
    Thanks for the clarifications, I was doing it all wrong ☹ all my coordinates are wrong.
  • Try
    M550 PSteam
    then run the assistant twice, followed by
    M117 Hey Hey-ey Goodbye
    (SCNR)
