Polar Not homing
I am working on building a polar printer and am having some issues homing.
I get the following Errors when i press home all and assimilate when I tried to home each axis individually.10:52:13 AMG28 Z
Error: Bad command: ''' File homez.g'''
Error: G0/G1: insufficient axes homed10:52:11 AMG28 Y
Error: Bad command: ''' File homebed.g'''
Error: G0/G1: insufficient axes homed10:52:08 AMG28 X
Error: Bad command: ''' File homeradius.g'''
Error: G0/G1: insufficient axes homed10:50:45 AMG28
Error: Bad command: ''' File homeall.g'''
Error: G0/G1: insufficient axes homedI did follow the Guide on setting Up the polar here https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwarePolarPrinter and the home files are the exact same as the ones given. the names are also the same as in the guide.
hrere Is my config.g
config.g
The instructions for writing homing files in the wiki page for polar printers was not up to date with current firmware. I have updated it.
Thank you, I will try again and let you know
I just checked the new homing files, and they seem to be the same and throw the same errors, is it possible that i am missing something?
Please post your homing files.
Here are my homing files. homez.g homeradius.g homebed.g homeall.g
What happens when you run this command:
M98 P"homeradius.g"
@dc42 said in Polar Not homing:
M98 P"homeradius.g"
The command M98 P"homeradius.g" shows the following in the console and slowly turns the bed for about 5 seconds. Ignore the motor phase issue I believe it is a loose wire. Sorry for the confusion between my forum posts. this is now in the right thread.
The commands in homeradius.g should move the radius motor, not the turntable. How have you assigned the motors? The X motor should control the radius, the Y motor should control the turntable, and the Z motor should control the height. If you have connected them differently, you can use the M584 command to change the assignments.
@Gregory said in Polar Not homing:
M98 P"homeradius.g"
I checked all of the motors and they are set up correctly, i also have end stops for every motor. The following video shows what happens then i hit home all. This also shows up in the console-
6:14:57 PMError: Bad command: ''' Home Z'''
6:14:57 PMError: Bad command: ''' Home bed'''
6:14:52 PMG28
Error: Bad command: ''' File homeall.g'''https://www.youtube.com/watch?v=5TuXlaT3wfw&feature=youtu.be
What firmware are you running?
