Trouble uploading files on duet wifi
Just did all the latest firmware upgrades, now when I go to upload a gcode file - it starts then fails anywhere from 20-50%. Is there some change that I need to make in my settings after doing the firmware upgrades?
did you upgrade the wifi firmware and the web controls as well?
yes, I just checked, and all the software numbers are current. I can log into the controller with no issues, and control it. This just becomes an issue uploading files.
what does the developer console of the web browser say when the upload fails?
Can you post the result of M122? Curious to see the wifi signal strength and some SD card info.
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04RC3 running on Duet WiFi 1.02 or later
Board ID: 08DDM-9FAM2-LW4SD-6J9DL-3S86M-KJWVX
Used output buffers: 3 of 24 (15 max)
Static ram: 25700
Dynamic ram: 92748 of which 416 recycled
Exception stack ram used: 320
Never used ram: 11888
Tasks: NETWORK(ready,516) HEAT(blocked,1232) MAIN(running,3740) IDLE(ready,160)
Owned mutexes:
Last reset 00:11:26 ago, cause: software
Last software reset at 2019-10-13 18:17, reason: User, spinning module GCodes, available RAM 11668 bytes (slot 0)
Error status: 10
Free file entries: 10
MCU temperature: min 34.6, current 34.9, max 35.1
Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2019-10-13 18:28:28
Cache data hit count 2726168254
Slowest loop: 4.49ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 202.13ms; fastest: 0.08ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
Failed messages: pending 0, notready 0, noresp 2
WiFi firmware version 1.23
WiFi MAC address 2c:3a:e8:0b:03:97
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 23696
WiFi IP address 192.168.1.50
WiFi signal strength -67dBm, reconnections 0, sleep mode modem
- WiFi -
@Veti Network Error
Spent all day on this to no evail. Reset my wifi network, tried different browsers, and another computer...same results.
The only common issue is the duet at this point.
Bet I'm getting. Is about 500k upload speed before it times out.
and will freeze about 20-50%.
any ideas? -
Do you have another SD card to try?
Just tried 2 other 4 gig cards - same result. they were both different brands as well. I even tried formatting them to both FAT32 and NTFS. No change.
Its gotta be something in the new WIFI firmware. Ive had this board for 2 years with no WIFI issues until the last update. -
Which firmware were you on before?
Can you try rolling back to see if it works again? -
Honestly I dont remember, I know its been at least a year since I updated this board. I thought it was time.
I had/have this issue since upgrading to the beta or the latest DWC - one of the two since I did both around the same time. I can get it to work when I change the printer orientation, and/or reboot my AP. It seems that it's much more finicky about signal strength or fluctuations. Eventually it can connect reliably again, after about 10 minutes from a cold startup and moving the printer so the controller board is oriented towards the AP location..
Just an update. I went ahead and did the ESP07-S external antenna upgrade after MONTHS of frustrations of updating and backdating firmware and drivers, etc.
THIS is the difference - 100%!!
For $16 (for TWO sets) and some time I now have NO ISSUES with file transfer to the printer. I think this is the module that should come with the DuetWIFI from the get go. I just bought another board for a new printer, and out of the box I did the mod.
I know they are focusing on the Duet 3 now, but if they are still going to produce the WIFI, they should consider this upgrade from the factory.
