    Problem with mesh bed leveling on modified M3D Promega
    • TheNetStrikerundefined
      TheNetStriker
      I'm trying to run the mesh bed leveling on a modified M3D Promega with leadscrews for the bed instead of the standard belts. I followed the manual from dehidding on Thingyverse:
      https://www.thingiverse.com/thing:3601545
      So far everything seems to work, but I'm getting a strange result when running the mesh bed leveling. All the points are way above the grid:
      What could cause this problem and how can I solve this?
      3ddevilundefined 1 Reply Last reply Reply Quote 0
      • 3ddevilundefined
        3ddevil @TheNetStriker
        @TheNetStriker I believe this is just in reference to your G30 command and how Z=0 was set in the first place. Now that you have the map, the absolute height is probably not relevant as long as you are testing G0 Z0 at a few points and it seems to be in the right place.
          Can you post your homing files and config.g?
          Are you homing with a probe using G30?
            TheNetStriker
            On a second try the level was already better. I now reconfigured the z homing so it is probing against the z probe and not the end switch. Now the height map levels are quite good.
