SOLVED G29 S1 when no heightmap is present causes startup failure
  • If you try to load a heightmap at the end of config.g and there isn't one yet, the DCS thows the following error and the Duet3 fails to start.
    err] Code G29 S1; Load and activate heightmap caused an exception: System.IO.FileNotFoundException: Could not find file '/opt/dsf/sd/sys/heightmap.csv'.
    ile name: '/opt/dsf/sd/sys/heightmap.csv'
      at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter)
      at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode)
      at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
      at DuetAPI.Utility.Heightmap.Load(String filename) in /usr/src/3d/dc42/workspace/DuetSoftwareFramework/src/DuetAPI/Utility/Heightmap.cs:line 72
      at DuetControlServer.Codes.GCodes.Process(Code code) in /usr/src/3d/dc42/workspace/DuetSoftwareFramework/src/DuetControlServer/Codes/GCodes.cs:line 65
      at DuetControlServer.Commands.Code.ProcessInternally() in /usr/src/3d/dc42/workspace/DuetSoftwareFramework/src/DuetControlServer/Commands/Code.cs:line 323
      at DuetControlServer.Commands.Code.Process() in /usr/src/3d/dc42/workspace/DuetSoftwareFramework/src/DuetControlServer/Commands/Code.cs:line 269
      at DuetControlServer.Commands.Code.Execute() in /usr/src/3d/dc42/workspace/DuetSoftwareFramework/src/DuetControlServer/Commands/Code.cs:line 204
  • Hi,
    You don't need to load the heightmap until you are ready to print.
    That doesn't happy until you have homed and set the "Z=0 Datum".
    After those are done then you can load the heightmap. Assuming you have created one.
    So remove that command from your config.g file
  • Yeah my point was that it used to be silently ignored and now throws an exception and prevents the Duet from starting.
  • @gtj0 said in G29 S1 when no heightmap is present causes startup failure:
    I see.
    But if you don't have that G29 (which you shouldn't) all is good - correct?
  • @fcwilt said in G29 S1 when no heightmap is present causes startup failure:
    I see.
    Kinda... You get:
    Height map loaded from file /opt/dsf/sd/sys/heightmap.csv
     Error: Command SimpleCode has reported an error:
    [FileNotFoundException] Could not find file '/opt/dsf/sd/sys/heightmap.csv'.
    which should be handled better.
    Again, I'm trying to flush out as many RRF3/DSF bugs as I can so that when the first production run of the Duet3 starts rolling out those users will have a better experience.
  • @gtj0
    You said in the past the error was "silent".
    Perhaps it is better if folks know something went wrong.
  • @chrishamm I updated pull request https://github.com/chrishamm/DuetSoftwareFramework/pull/68 to catch IOException and print an error message instead of letting the exception bubble up. Done for G29 S1, G29 S3, M374 and M375.
    G29 S1
    Error: Could not find file '/opt/dsf/sd/sys/heightmap.csv'.
