Delta experts: feedback appreciated
Making the plates round would be fairly simple, although I have no plans on making a chamber.
Just updated again. Moved the carriage adapter in front of the belt. Now I have 23.6deg angle on the edge and more clearance near the towers: Minimum of 18mm between the edge of the smart effector and the belt.
I think I am almost done with th ebasic frame layout.
I just received an email about the Zesty Nimble V2. I did have a nimble before, but wasn't 100% satisfied.
Now I am in doubt about the extruder setup:- Fying extruder
- Nimble V2
- Or 4th axis extruder?
Drew up a first concept for the 4th axis extruder mount:
So, I would like some feedback/ verification:
With a 240mm bed, I now have:
- 25deg at the edge of the bed, opposite a tower
- 85deg, at the edge of the bed, nearest a tower
- 61deg in the middle of the bed.
Are these numbers ok?
Yes, the "rule of thumb" limit on low angle is 20 degrees (and that always occurs opposite a tower). You are comfortably away from that. None of the other angles really matter.
@Danal Thanks, I thought I saw DC42 mention somewhere that the center or high angles can have an affect on resolution. But it's hard to find any info on that. Thats why I asked for verification.
I can still put a 260mm bed in this setup, and the low angle then is about 22deg.
@bartolomeus said in Delta experts: feedback appreciated:
- Nimble V2
I have used Nimbles on all my printers and they have worked well for me.
What problems did you have?
It would be much simpler than a flying extruder.
I would go big. 22 is fine.
@fcwilt said in Delta experts: feedback appreciated:
- Nimble V2
I never totally got rid of the wave pattern on the surfaces, even after I used the specified grease and also after they sent me a new worm gear.
Just another thought.
Even if you don't go with a flying extruder you might want to keep the two additional "towers" and design some diagonal bracing between them and the rear tower.
Keeping things square with no bracing can be a challenge.
@Danal Maybe in the future, I have a new 240mm bed ready to be installed. I'd like to have a 260mm one made out of tooling plate, but my funds have vanished....
- Nimble V2
Hmm...
I had problems with my deltas but that wasn't one of them. What was the supposed cause?
- Nimble V2
Hmm...
In the beginning many people had wave patterns on the surface of their prints with a Nimble. Most of these patterns disappeared by replacing the supplied lubricant with some silicone grease. The Nimbles are now supplied as standard with the silicone grease I believe. But somehow I couldn't get rid of it.
Thanks for that info.
I guess I got lucky.
Whilst waiting for parts to arrive, I modified the design to a standard 3 tower delta. As a result the footprint is alot smaller.
I wonder if you will be able to get the vertical extrusions square to the base and top.
Screws into the ends of the extrusions won't have much leverage.
Looking forward to your progress.
Thanks.
Thanks.
Same here. I am relying on the supplier of the extrusions that they are precisely cut and the same length.
Otoh, the 3 tower frame is only 5 parts (2 plates and 3 towers). My (upgraded) Anycubic Delta frame was made of 18 parts (6 corners, 3 towers, 9 horizontals) and it printed pretty good. I am hoping the lower part count and precisely machined parts will pay off.
Thanks.
These are the reasons why I went with 4060 on mine, because it has a wider base and instead of the screws being all on one dimension, they're on two.
I also got mine milled square by a machine shop. It's incredibly accurate when done right.
@blt3dp said in Delta experts: feedback appreciated:
Thanks.
I did start out with a design based on 4060, but figured it would be overkill for a 240mm bed. I have already started on a 320-330mm bed version which will use 4060, however I am not sure if I will continue with the design or if I will build it.
