Induction probe compensation
After long time i came to the conclusion that my induction probe drifts and its caused by heat from the bed. Is there a way to compensate probe drift?
@Agniusm said in Induction probe compensation:
Yes. In RepRapFirmware 2 you can compensate for probe drift caused by changes in the reading of the bed temperature sensor. In RRF3 you can use any temperature sensor. See the C and S parameters of the G31 command.
