BLTouch does not work anymore if M558 executed twice
I would like to configure a BLTouch (Version 3.1) probing that first probes fast and then slow. But the problem is that the probe stops working when I execute the M558 command a second time. After that I have to power down the Duet board completely to get the probe working again. This is the command I'm using:
M558 P9 H5 F300 T2000
Does anyone have the same problem and what could cause this problem?
Can you send M115 to the printer, and post the response here? This will show your firmware version, Duet Hardware type and version. Please also post your config.g, so we can see how the probe is setup. Finally, please post the EXACT code (first and second M558 commands, and any preceding relevant gcode) you are sending that causes this issue.
Rather than try to change the Z probe feed rate could you temporarily limit the feed rate to the slower speed by using a M203 command?
@droftarts Here is the output of the M115 command:
FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2019-06-13b2
And those are the command I'm executing:
M558 P9 H5 F300 T2000 ; Executed by config.g
M280 P64 S10 ; Deploy probe => works
M280 P64 S90 ; Retract probe => works
M558 P9 H5 F100 T2000 ; Execute command again
M280 P64 S10 ; Deploy probe does not work anymoreA reset of the Duet board also fixes the problem until the command is again executed a second time after the system is started up. I've uploaded the whole content of my sdcard to GitHub. There you can see all gcode files that I'm currently using:
https://github.com/TheNetStriker/Promega/tree/LeadscrewBondtechV6/SD Card Structure/Compound/sys
@fcwilt You solution seems to work. I will use this as a workaround until a fix for the problem is found.
Well at least you have a workaround.
While I have NOT actually done this with the most recent firmware in the past I have used macros to change Z-probe type as I had interchangeable Z-probes.
Perhaps changing from P9 to P0 and then back to P9 might work.
@fcwilt I've just tried that but that also doesn't work. The probe is just not doing anything after the second command.
@TheNetStriker said in BLTouch does not work anymore if M558 executed twice:
As I suggested perhaps the firmware you are using works differently from what I was using when I was changing Z-probe type but I was able to change from one to another and back again.
The difference being I was not trying to change any of the parameters.
I would do this myself by I am out of town so Just as a test execute the M558 twice with the same parameters and see if that also causes the Z-probe to stop working.
