Duet wiring sensors sharing ground?
  • Can I share a ground from 3 sensors on my hotend? For example, I have the magnet filament sensor, a X endstop switch, and and DC42 IR bed Z sensor. when running the wires from my hotend can I use the same ground for all 3 of those sensors to save running 2 ground wires? Will that cause any issues?
    I'm assuming it would be ok since they are getting a seperate V and S line to each
  • I should specify, I am using a breakout board at both ends so the grounds would split off to their specific connectors from the breakout 2 all three connectos for the sensors on the duet board
