    How setup Slic3r 2.x?
    • peirofundefined
      peirof
      i am giving a try to Slic3r v2... when i start to print, i see often a message in console...
      Warning: M73 command is not supported
      I have see its a command, M73, not supported by Duet....
      There is some form of configuration Slic3r, to generate a gcode, more compatible with Duet??
      Thanks
      • mloidlundefined
        mloidl
        I'm pretty sure if you select RepRap/Sprinter as Firmware Type then no M73 GCodes are created.
        Alternative you could create a empty file called /sys/M73.g. This should work with firmware > 2.03 as described in https://duet3d.dozuki.com/Wiki/G-Codes_not_implemented
        peirofundefined 1 Reply Last reply Reply Quote 0
        • peirofundefined
          peirof @mloidl
          @mloidl said in How setup Slic3r 2.x?:
          i will try create M73.g, because i have selected Reprap/Sprinter mode.... and the error messages flood the console
          • mloidlundefined
            mloidl
            Later i'll check why i'm not getting these messages. Maybe it's a kind of configuration somewhere
            • Vetiundefined
              Veti
              @peirof said in How setup Slic3r 2.x?:
              disable the support remaining times flag
              • mloidlundefined
                mloidl
                Can now confirm that "Supports remaining times" is what you have to untick to not get these M73 GCodes.
                • peirofundefined
                  peirof
                  Thanks....
