    Mesh calibration not working or what am I doing wrong?
    93
    5.2k
    • Depundefined
      Dep
      Yes, I understand that.
      But mesh calibration measures this deflection. Why is it not compensated during printing?
      • Vetiundefined
        Veti
        @Dep said in Mesh calibration not working or what am I doing wrong?:
        M557 X500:1000 Y150:600 S25
        thy with M557 X500:1000 Y150:600 S10
        Depundefined 1 Reply Last reply Reply Quote 0
        • Depundefined
          Dep @Veti
          @Veti said in Mesh calibration not working or what am I doing wrong?:
          This is unfortunately impossible 😞 The maximum number of points is 121
          • Depundefined
            Dep
            But part of the model in the photo falls into several calibration points. Why are they not aligned?
            • Vetiundefined
              Veti
              https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
              There is a firmware-dependent limit on the number of 441 probe points allowed.
              • Depundefined
                Dep
                I have a 0.8.5 board. And when i try to make more than 121 points, it gives an error.
                But even with this number of points. They overlap the model. Why is it not calibrated.
                I think there is some kind of limit on the calibration height.
                I have spent many days and can not solve this problem.
                There is no technical possibility to make a flat table on such sizes.
                I don’t know what to do next. 😞
                • Vetiundefined
                  Veti
                  what firmware version are you using?
                  • Depundefined
                    Dep
                    Duet 0.85
                    RepRapFirmware for Duet 1.25RC4 (2019-10-19b1)
                    • Depundefined
                      Dep
                      03.11.2019, 14:40:36 M557 X500:1000 Y150:600 S10
                      Error: M557: bad grid definition: Too many grid points; suggest increase spacing to 47.4mm
                      • Vetiundefined
                        Veti
                        try decreasing the mesh area and see if the result improves, allowing more probing points in a smaller area.
                        • Depundefined
                          Dep
                          I tried to reduce to 20mm. That helped. But now I don’t know, maybe I came across a flat section of the table?
                          But I need the printer to work on a large table. I don’t understand what the problem is.
                          Why calibration is not working? There may be some kind of configuration problem.
                          After all, in theory, for firmware it does not matter how uneven the bed is.
                          Either there are limitations in the firmware, or maybe the adjustment is not accurate and it is not visible at small values. But it becomes noticeable with a large roughness.
                          Vetiundefined 1 Reply Last reply Reply Quote 0
                          • Vetiundefined
                            Veti @Dep
                            look at the mesh calibration image to check.
                            • Depundefined
                              Dep
                              If you mean to look at the program code, then unfortunately I am not good at programming.
                              • Vetiundefined
                                Veti
                                no the image of the you see after running mesh bed compensation.
                                • fcwiltundefined
                                  fcwilt
                                  Have you ever defined a probing grid that covers the entire bed?
                                  If not would you do that, probe the bed and post the height map here?
                                  Thanks.
                                  • Depundefined
                                    Dep
                                    Made a calibration with the parameters: M557 X500:700 Y150:230 S20
                                    RepRapFirmware height map file v2 generated at 2019-11-03 18:06, min error -0.633, max error -0.047, mean -0.346, deviation 0.137
                                    xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                                    500.00,700.00,150.00,230.00,-1.00,20.00,20.00,11,5
                                     -0.329, -0.318, -0.282, -0.248, -0.238, -0.218, -0.195, -0.176, -0.133, -0.089, -0.047
                                     -0.377, -0.358, -0.342, -0.314, -0.324, -0.287, -0.280, -0.235, -0.199, -0.162, -0.118
                                     -0.484, -0.434, -0.434, -0.435, -0.375, -0.344, -0.337, -0.308, -0.259, -0.216, -0.163
                                     -0.541, -0.507, -0.491, -0.479, -0.467, -0.427, -0.433, -0.389, -0.338, -0.282, -0.226
                                     -0.633, -0.607, -0.580, -0.550, -0.533, -0.510, -0.484, -0.463, -0.407, -0.353, -0.298
                                    I still can’t understand what this can give us? 🙂
                                    • Depundefined
                                      Dep @fcwilt
                                      @fcwilt Bed Size X1380 Y1210
                                      I only calibrate 500 x 500
                                      But the part fits in this size. It is inside a calibrated space.
                                      Do you think if not the entire bed is calibrated this can cause an error? But how to do that? Maybe reduce the table and set offsets?
                                      • fcwiltundefined
                                        fcwilt @Dep
                                        One height map you posted was absolutely terrible.
                                        I just want to get picture of the entire bed as a reference.
                                        Not having the entire bed calibrated shouldn't cause an error unless you try to print outside that area.
                                        But there is not much point in having a large bed if you cannot use it all.
                                        Thanks.
                                        • Depundefined
                                          Dep @fcwilt
                                          @fcwilt said in Mesh calibration not working or what am I doing wrong?:
                                          Now I can’t make a height map of the whole table, because glass 650 x 650 mm is fixed on the table
                                          Yes, the bed is very crooked. But why doesn't compensation work? Does it really matter how rough the bed is?
                                          Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                          • Vetiundefined
                                            Veti @Dep
                                            with a bed as uneven as that it does.
                                            the points in beetween probing are calculated and dont reflect what is actually there.
                                            so if the bed is not uniformly uneven it will be off.
                                            with it beeing off by an entire layer means this error can be significant.
