Fans... Layer fans.
  • Hi,
    After sometimes o go back to print PLA... And i have a issue, layers fans dont start automatically... I have to start by DWC....
    I have this, in "config.g":
     M106 P0 S0 I0 F500 H1 T80
     M106 P1 S0 I0 F500 H-1
     M106 P2 S0 I0 F500 H-1
    There is some system trigger on a macro when a layer has reach?
  • Hi,
    By "layer fans" I assume you mean that fans that blow on the part being printed?
    Control of these is usually set in slicer.
  • I have configures layer fans for go on in 2 layer
  • @peirof
    have a look at the generated slicer code for the command to turn on your fan.
  • As I recall by default Fan 0 is the part cooling fan and Fan 1 is the extruder cooling fan.
    It seems as if you have that reversed so you have to make an adjustment in the slicer to let it know that Fan 1 is your part cooling fan.
  • @fcwilt said in Fans... Layer fans.:
    Or one can define which fan to use in the tool definition and leave the slicer as is.
