Homing problems sensorless and PINDA
Hi, I hope Google Translate it well.
I am currently updating my Sidewinder, he gets Duet Wifi with 5 inch display, sensorless homing and Pinda. I got it started, the probe responds to my Pei plate. Now I have problems with homing. When I drive an axis it drives home but does not stop walking. He rattles at the endstop, as well as the bed.
Homing macro.txt
homez.g
homey.g
homex.g
homeall.g
config.gDoes anyone have a good tip for me.
Greetings from Germany
sensorless homing needs to be calibrated to work for your specific setup
see
https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
it does not work by just turning it onto see if the duet sees your probe triggering use the M119 command
https://duet3d.dozuki.com/Wiki/Gcode#Section_M119_Get_Endstop_Status
I have read the doku and changed the config.g as described. Are the files I uploadet not displayed?
from your config
M915 X Y S3
this does not look like a fine tuned M915 command
you have configures no action to be taken.
you are not changing current nor have taken care of the minimun speed.
