    Problem with temperature sensor mark 2000°
    printer
    627
    • kyllundefined
      kyll
      Hello when i plug the temperature sensor with the daughter board and the resitance the temperature on the the screen is 2000° someone know how to resolve it ?
      • wilrikerundefined
        wilriker @kyll
        @kyll We need some more information to answer:
        • What type of sensor (mentioning daughterboard I would assume PT100 but please confirm that)
        • RRF version (M115)
        • Have you configured the sensor? (M305 for RRF 2.x or M308 for RRF 3) If so please post the condiguration
        Manuel
        My Tool Collection
        • kyllundefined
          kyll
          The sensor is this one :https://e3d-online.com/pt100-temperature-sensor and i'v tried to change the config file by typing M305 P1 X200 at the place of the heater
          • Vetiundefined
            Veti
            did you verify the resistance of the pt100 sensor?
            did you connect it to the correct terminal?
            just checking. you do have the duet daughterboard and not the e3d daughterboard?
            • kyllundefined
              kyll
              • kyllundefined
                kyll
                • Vetiundefined
                  Veti
                  when you enter M305 P1 X201 in the console(not the config) does it also show 2000?
                  • kyllundefined
                    kyll
                    • Vetiundefined
                      Veti
                      that means it cant talk to the dauthterboard.
                      did you connect it the correct way round?
                      • kyllundefined
                        kyll
                        • Vetiundefined
                          Veti
                          that is the wrong way.
                          compare the documentation
                          https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
                          the spacer should line up
                          • kyllundefined
                            kyll
                            Ok but right now the screen show -0.2°
                            • Vetiundefined
                              Veti
                              @kyll said in Problem with temperature sensor mark 2000°:
                              -0.2°
                              thats the 100 ohm resistor. now switch the channel
                              • kyllundefined
                                kyll
                                On it's working thank you so much
