Duet 3 questions
I was wondering if anyone could help me with figuring out if the duet 3 will run nema 34s on a 4ft by 8ft cnc machine? Also if I could control a spindle?
@nightmare90gt said in Duet 3 questions:
it depends on the nema 34s rated current (assuming its not a 5 wire stepper)
The 5160 steppers support 4A RMS, 5.6A Peak.for an example for spindle see
https://openbuilds.com/threads/workbee-cnc-w-duet2-and-chinese-spindle-control.14004/
Being pedantic but it's not the drivers (edit: specifically the 5160 drivers) that limit the current to 4A, it's the external MOSFETS.
Interestingly there is a conflict between the Duet3 sales stuff on the Duet3D site and Thomas Sanladerer's video which has a 6A splash /thumbnail. Just watching it for clarification....
Edit: Video: https://www.youtube.com/watch?v=W6U-u0wBdfQ
Yup, @T3P3Tony says up to 6.3A peak just after 06:00 point of the video. Maybe this has been revised down, or relies on cooling where as the 4A doesn't?
The ones the machine manufacturer has listed have 1.55v and 7A but I am unsure if that means 7a peak.
I imagine the maximum voltage would be 24v going to the steppers?
see
https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview
VIN in the range 12V-32V
I would image you would put 24v in the input to drive all the other sensors or do I have that wrong and you would just supply the input the 32v. Another possibility would to put the 32v on the high current.
@DocTrucker said in Duet 3 questions:
Copy and paste from the hardware overview :
"Maximum motor current 6.3A peak per phase (4.45A RMS)."
@deckingman also cut and paste:
6 Next Generation Trinamic 5160 stepper drivers running at up to 4A RMS, 5.6A peak with firmware control of the full feature set including up to 256 microstepping, StallGuard 2 and StealthChop2
@DocTrucker It seems that you pays your money and takes your choice - my source of info was this https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview.
Either way, if we round to the nearest integer, we get 6A peak, 4A RMS so I suggest we run with that
Edit - That latest link of yours was very old - pre any thermal testing I'd guess.
@deckingman I'd just ran an internet search on Duet 3 and those where the top links. Hopefully airing them will lead the admins to delete or amend. Think one of mine is the shop link.
I have tested the expansion boards driving 3 stepper motors simultaneously at 4.5A RMS (6.3A peak). I don't have enough high current stepper motors to test all 6 on the main board simultaneously at that current. That's one of the reasons why we've been cautious about specifying the rated current on the main board. The firmware will allow 6.3A peak. We'll do some more tests next week when we expect to have the first version 1.0 main boards.
At high motor currents, the firmware enforces a maximum standstill current percentage. This maximum reduces from 100% at 4.5A or lower peak current setting to 70% at 6.3A peak current setting. The purpose is so that each pair of output mosfets carries at most 4.5A RMS current, whether moving or at standstill, to avoid overheating individual mosfets when the motors are standing still.
@dc42 said in Duet 3 questions:
Look forward to seeing the results.
If I do the calculations for the nema 34 the max voltage is 45 which I wouldn't want to do for heat purposes. So if I apply 32v to the motors that will put me at 70%. Is there a way to figure the amperage at 32 volts?
Do you mean that is the voltage you need at the highest speed you want to run the motors? Or something else?
The max voltage the motor should be driven from my understanding.
There are two voltages commonly specified for stepper motors:
- The phase voltage is the resistive voltage drop at the rated current. It should be much less than the VIN voltage, but is otherwise irrelevant when using constant current drivers (which Duets and all other modern control electronics use).
- The insulation rating. This is usually many tens of volts, and should be higher than the VIN voltage used.
https://www.geckodrive.com/support/step-motor-basics/power-supply-basics.html
This is how I found the max voltage for the motor sounds like the insulation rating your referring to above.
The formula they give:
32 * √L = VMAX
is specific to the Geckodrive, and does not translate directly to other drivers. What it suggests to me is that the Geckodrive has a minimum quantum of time by which it can adjust the on-time, and that time quantum is quite long.
It's true that very low inductance motors and high supply voltage could be problematic, but to be a problem for the Duet 3 drivers I think the inductance would need to be well under 1mH even with 30V supply.
Ah ok makes sense thank you for clearing that up for me.
So are you saying that because the motors in question have a inductance of 2mH I wouldn't be able to use the Duet 3?
Yes, no problem.
