G32 w BLTouch and Z-endstop
@jontek2 said in G32 w BLTouch and Z-endstop:
According to the documentation (https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe) the M557 commands is used for the Touch-Mi.
That is simply mentioned there because of the characteristics of that type of probe.
M557 is used to specify the area to be probed for mesh compensation.
From the docs:
M557: Set Z probe point or define probing grid
Parameters to define G29 probe grid (all values in mm)Xaaa:bbb Minimum and maximum X coordinates to probe
Yaaa:bbb Minimum and maximum Y coordinates to probe
Raaa Radius to probe
Saaa Probe point spacing (RepRapFirmware 1.19beta10 and later also support Saaa:bbb)
Pnn or Pxx:yy (RRF 2.02 and later) Number of points to probe in the X and Y axis directions (alternative to specifying the probe point spacing) -
Hmmm then why are there a function in the GUI for "Define Area for Mesh Grid Compensation"?
Does the same thing.
Using the command is my approach.
I have two macros for running mesh compensation.
The first sets up a simple 4 point grid just to get a quick view of the overall levelness of the bed. I first did this when I was leveling the bed manually.
The other is for the full mesh compensation using points on a 20x20 grid.
Each macro uses the M557 command to specify the desired grid.
With the most recent DWC using the menu option to specify the grid mentions the M557 command.
Alright, i'll look in to that.
What's your start G-codes? Do you run the G29 in the start G-code?
I'm currently using:
;;; STARTING SCRIPT BEGIN ;;; G28 ; Home G29 ; Bed leveling G92 E0 ; Zero extruder G1 X120 E20 F600 ; Draw prime line ;;; STARTING SCRIPT FINISH ;;;
Currently I only run bed leveling (G32) and mesh probing (G29) manually from macros for two reasons.
They take a while and the printer seems to be doing well with just doing those processes occasionally.
My Z homing procedure...
- clears mesh compensation
- cancels any "baby-stepping"
- homes using a end stop switch
- sets the Z=0 datum using a BLTouch Z-probe
- loads the most recent full bed mesh compensation file
This happens whenever Z is homed so the normal "begin print" process doesn't need any special actions related to them, it just does the normal things related to set temps, selecting tools, priming and cleaning nozzle, etc.
