STEPPER AND HOMING PROBLEMS
I recently made some changes on my corexy FT5-2, running Duet2wifi. I made no firmware changes, but did have to re-pin new connector for x axis. All wires are in the correct positions in the connectors, and are connected to the board correctly.
Everything worked fine before these changes, not so now. I also verified continuity of all wires for the stepper. Now when I try to home x or y, all I get is that loud ratcheting noise, and neither x nor y will home.
I opened up YAT this morning and it gave a warning : RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.02(RTOS) dated 2018-12-24b1
Executing config.g...HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: M569: Driver 0 does not support mode 'stealthChop'
Error: M569: Driver 1 does not support mode 'stealthChop'
Error: M569: Driver 2 does not support modWarning: VIN under-voltage event (9.5V)I sure hope someone can help straighten this out.
@swrightlast said in STEPPER AND HOMING PROBLEMS:
bad power supply?
why are you trying to set stealthchop on a duet2 wifi?
@Veti Not trying to set up stealthchop, that's what showed up when I connected YAT this morning.
Check the PSU voltage output with a multimeter.
@Phaedrux 24.63vdc
Something may have been dislodged or damaged during the operation?
Retrace your steps and recheck the wiring.The description of the X and Y axis sounds like it could be a disconnected or intermittent phase connection on the steppers. Best to recheck the wiring first before doing any further live testing. Disconnecting a driver while it's powered is a good way to kill it.
I would add that you can test each motor individually which will help to narrow down the problem. See here https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter and check out the Movement Section.
@swrightlast
whats the voltage reported in the dwc?
@Veti 24.6
@Phaedrux If tat's the case, can you replace individual drivers? How do you test drivers?
@Phaedrux said in STEPPER AND HOMING PROBLEMS:
kill it......the driver or the stepper?
The driver. But hopefully it hasn't come to that. Not exactly a user replaceable item for most.
any way to directly test the driver? if the driver's fried, does that mean a new board (choke, choke) ?
Well given the low voltage warning it could just be a power wiring issue.
If it did happen to be a dead driver you have the option of remapping the axis to use an unused driver.
Or if you didn't have a spare driver you could add more drivers with a cheaper Duex2 expansion board.
But first let's check the wiring.
Yes, as deckingman posted above the link there has directions on issuing commands to test each individual motor separately. But before you try and move the motors again, check the wiring.
@Phaedrux . As stated earlier, I checked stepper motor wiring, and have continuity from motor to board on all 4 wires (connector to connector). Anything wire wise to check?
What exactly does this mean? What did you re-pin? How did you do it? Why?
@Phaedrux , Had to put new connector on stepper wires (crimp on new pins), at the board end. Have continuity from motor end to board end at the connectors. I made no changes in config.g or the homex,y,z.g. It worked fine before wiring, so, to me it would indicate a wiring problem. I'm just at a loss as to what to check next.
I'd probably start with re-crimping the ends.
@Phaedrux , Recrimped....no change (sigh).
@swrightlast Have you tested each individual motor as I suggested? If so, have you tracked it down to either the X (alpha) motor or the Y (beta) motor or both? If one motor works fine and one does not, then you could try swapping the motors. If the problem moves with the motor, then it;s the motor. If the problem persists, then it could be the driver.
Out of curiosity, what were the changes you made which led to you having to fit a new connector?
@deckingman , I'll check that again. Answer to your other question: I was enclosing motor wires within the 2020 extrusion, and needed to clip the wires at the board connector to enable feeding the wiring.
I checked motor movement.....I get a short grunt of ratcheting noise, and NO movement on either axis.
If you disconnect the belts from the pulleys do the motors spin individually using this sent from the console:
G91 G1 S2 X10 F3000 G1 S2 Y10 F3000
Do you still get any errors in the console?
