Extruder clicking/going backwards
@Veti said in Extruder clicking/going backwards:
@pedromelim said in Extruder clicking/going backwards:
only happens when attached to the extruder but the motor on its own does the same movement.
as deckingman said. the backwards movement is exactly how Pressure advance works.
check the grub screws inside of the bmg. they can become loose as well.
Checked them both, they are all ok.
I managed to print a full benchy with the base values i started with, without pressure advance, and im getting mixed results.
When it prints slowly i get very nice finish but there there are parts that i get underextrusion and over extrusion. Its really weird.
http://prntscr.com/ptnkrn
http://prntscr.com/ptnl82
http://prntscr.com/ptnlfcwith this config:
M92 X80.00 Y80.00 Z400.00 E409.31 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
M203 X15000.00 Y15000.00 Z300.00 E8000.00; set maximum speeds (mm/min)
M204 P6000 T6000 ; Set printing and travel accelerations
M201 X6000.00 Y6000.00 Z60.00 E3000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeoutRetraction was between 5 or 6.5, not sure wich one and sretraction speed 60mm/s.
M204 P6000
Your print accelerations are really aggressive. Try M204 P1000
What slicer are you using?
@Phaedrux said in Extruder clicking/going backwards:
M204 P6000
Prusa Slicer, and i would prefer still keeping using it as i have an Mk2.5
60mm/s.
i had problems when i went above 40mm/s retraction speed.
my problem was the slicer (cura) i had "use adaptive layers" on under experimental setting
