Endstop error
End stop problem
I have a duet wifi 2 which I am installing with an Ender 5. everything has gone well.
but i have a problem with my endstops, everything seems to work but the steppe motor does not stop when it reaches the endstop. It does not detect that it should stop. so it crashe.I have in frustration come to put the wires wrong, so also fear that I may have shorted something.
Sorry about my English, I'm using google translet.
please read
https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches
and look at the testing part.
also post your config
; generated by RepRapFirmware Configuration Tool v2.1.2 on Thu Nov 07 2019 17:27:04 GMT+0100 (Centraleuropæisk normaltid); General preferences
M550 P"Ender5" ; set printer name
M918 P1 E4 F2000000 ; configure direct-connect display; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X250 Y250 Z300 S0 ; set axis maxima; Endstops
M574 X1 Y1 S1 ; set active high endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M307 H4 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T3000 ; set Z probe type to bltouch and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X41 Y9 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:230 Y15:230 S20 ; define mesh grid; Heaters
M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S275 ; set temperature limit for heater 1 to 275C; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
I have tested endstop in machine probeties, and they go from no to yes when i enable them.
use a multimeter and measure the resistance on the connector. triggered and untriggerd.
OK I have measured on endstop with multimeter 20k, they go from 0.00 to -8.30 when activated.
hope it makes sense
-8.3 makes not much sense. there is no negative resistance. but there seems to be a change.
config looks fine.
please post the output of.
M119 when press x and when pressed y endstop.also you are aware that your board is not a genuine duet board?
We'll also need to see your homing files.
here's what it writes when I send M119
the first is triggered, the second is not triggered:1: 21.28.07M119
Endstops - X: at min stop, Y: at min stop, Z: not stopped, Z probe: not stopped2: 21.28.22M119
Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stoppedDid not now that it was not a duet I had bought, but can see that it says on the back that it is a copy.
sorry if i have wrongly asked for help.
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H2 Z4 F3000 ; lift Z relative to current position
G1 H1 X-240 Y-240 F1500 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F3000 ; go back a few mm
G1 H1 X-240 Y-240 F120 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 H2 X-26 Y6 F3000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S1 Z4 F50 ; lift Z relative to current position
;G90 ; absolute positioning
; homex.g
; called to home the X axis
G1 H2 Z5 F3000 ; lift Z relative to current position
G1 S1 X-255 F1500 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F3000 ; go back a few mm
G1 H1 X-255 F120 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F3000 ; lower Z again
Are you sure that you don't have the X and Y endstop connections swapped, or the X and Y motor connections swapped?
@lacs2711 said in Endstop error:
1: 21.28.07M119
2: 21.28.22M119
Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stoppedthis means they trigger correcly.
can you test x and y seperatly. you might have swapped them around.
I'm pretty sure they are not swapped, here M119 along with a picture
21.51.57M119
Endstops - X: at min stop, Y: not stopped, Z: not stopped, Z probe: not stopped
what firmware version did they supply the duet with?
Let' start with homing X by itself. Your homex.g file is this:
; homex.g
G90 ; absolute positioningThe line starting G1 S1 should really start G1 H1, but unless you have accidentally set the Duet to laser mode, it doesn't matter. Try changing it to G1 H1 anyway.
You've already checked that the X endstop switch reads correctly in M119. When you try to home just X (using the web interface, or by sending G28 X), does it move the carriage towards the X endstop switch?
when I try to home X it says
22.06.50G28 X
Error: G0/G1: insufficient axes homed
22.06.50G28 X
Error: G0/G1: insufficient axes homedAs @Veti already asked, please tell us what firmware version you are using. Send M115 to find out.
firmware version 2,03
sorry
M115
22.10.39M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-06-05b3
sorry
M115
22.10.39M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-06-05b3That version is too old to understand G1 H commands. I recommend you upgrade to 2.04.
OKI will try it tomorrow. thank you so much.
This guide may help you in your testing. The Ender 5 and the Ender 3 are basically the same setup.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
