Windows 10 3D printing support
Apologies if this is already answered somewhere, my duckduckgo fu is not at the highest level these days
.. anyhow if it is please hook me up with url
As we know Windows 10 has some 3D printing support. Now, while I actually never tried this nor have a clue how the whole concept of windows 10 and 3D printing works, I have to ask - is there a way to have Duet2Ethernet board visible on the Windows 10 host (trough network or trough USB, ideally both)?
@smece
"Visible on the Windows 10 host" - what does that mean?
@fcwilt afaik, prusa mk3 will show up here
also, I had my teartime printers show up here too while I was using their original electronics.
I did not ever use this, but I'm interested in how it works and if duet can support it
(mostly in order to figure out how that works)
I think that is something in Window's future.
I think it's only USB-connected printers that show up there, and printing over USB is a bad idea.
@fcwilt I think it is current, not future as it exist for a while now (more then I year I think) and windows comes with some 3d tools that are not that bad neither (the 3d builder is the fastest one to merge all objects in multiobject stl for e.g. out of all tools I tried) .. so I believe it is something we at least should be aware of, irrelevant if we are supporting / using it or not
@dc42 I have zero experience printing on duet so can't say much about it but printing on smoothieware trough usb with octoprint works flawlesly for many years on many of my machines, it does not work very good on marlin as the 8bit mcu can't handle the load but that's another issue all together.. so I assume duet can handle gcode stream arriving from usb...
anyhow, I'm not 100% sure it's usb only as I am almost sure that my up mini was visible on my win10 box and up mini was only accessible trough wifi, can't be sure now and can't retest as I removed original electronics from teartime printers (their old slicer was good, the new one is not that much and they use proprietary protocol so I scrapped the electronic) ... also, even for usb, if we look how other windows printers work, you can send a "whole file" (EPS, PDF, PCL...) to the printer for printer to "process" and finally print, I doubt that the only way windows printing would be to stream realtime g-code to the printer, I rather believe you either shoot the g-code to the printer and start print (standalone) or you send stl/3mf to the printer/driver and let it handle it (convert to g-code, send to printer, whatever...) .. and I kinda believe it is the latter as neither of the printers I owned that shown in the list of 3d printers on windows supported g-code
in any way, while I'm totally happy with the workflow as is today, I'm just interested how this whole windows thing work so assumed someone on the forum already did some research
so I don't have to
@smece How does windows 10 handle the smoothie setup over usb? Does the printer get listed automatically, or is it meant to be installed manually?
@bot said in Windows 10 3D printing support:
you missunderstood me, I converted TT printers to smoothie so they are no longer visible on win10. they were visible on windows 10 before conversion, with original electronic and original software (slicer, driver ...), and I never actually tried printing from any of the windows tools (at the time was not something that interested me) so I have no clue how it works... recently I read that prusa's printers are visible on win10 so I assumed someone knows more about it (as afaik those prusa drivers are open source) and hoped maybe duet3d is on the same path... again, more 'cause I'm curious than anything else
and now I have no printers that do support that so ..
These are my personal thoughts and gripes:
The windows 10 3D printing apps are yet another half cocked unfinished example from the Microsoft 'software experts'.
These days Microsoft tend to start a project but never finish it and then later abandon it.
As far as I remember 3D Builder came with the first distribution of Windows 10 and has exactly the same features now as it did then. The help files tell you very little and there is no guide anywhere of how to connect printers. I don't know of anyone who uses it and Microsoft gives me no incentive to start using it.
@chas2706 said in Windows 10 3D printing support:
not these days really, it was like that since DOS 2.0, but I tend to not take that as a bad thing, doing stuff on many fronts is imo a valid strategy.. the only difference is they are now sharing their rnd compared to many others (and compared to m$ in the past, that's why you say they "these days tend to.." .. these days they tend to share most of the rnd while earlier they didn't)
Yes, but for e.g. you have a multipart (multi-shell) STL that slicers slice wrongly 'cause of that and you need to merge them .. netfabb professional does it but cost arm and a leg (and mine for e.g. does not work any more as the dongle I have require licence file too and since my previous computer died I don't have it any more and noone from previous netfabb contacts are answering emails anyu more so that's 1000eur down the drain) ... 3D builder, open, edit, select all, merge, export and it's done, super fast and flawless
... I have not used it to do some modeling / editing but this is useful enough
With exception of maybe Prusa printer the only one that support this out of the box are the commercial printers with proprietary electronics so no wonder why "noone uses it" .. but if more printers support it maybe more ppl would be using it and we might find it's actually useful
(or we'd figure out it's a total scam) .. but for e.g. inside SolidWorks there's a "3d print" option that works only on windows 10 ... I would, for e.g. love to know how that works .. is SW just sending the stl equivalent to the "driver" that's going to be slicing it or there's something else going on there.. aren't you curious how is that support to work? I know I am! I'm 80% sure it's going to be useles but still, I wanna know, not guess
Just my two cents:
Win 10 support is indeed for USB attached printers.
USB attach does work, and we've all used it.
USB attach has its pros and cons (widely known, so I will skip them here)
And, most importantly:
- Using USB with a duet is bypassing a huge portion of its value
Duet is designed from the ground up for web-based "upload then print". Trying to use Win USB, or Octo, or whatever, is a huge step backwards for Duet. Don't let your past rob you of value with this wonderful controller. Use it the way it was designed.
@smece said in Windows 10 3D printing support:
think you'll find the majority* of the 3d printing community will ignore the closed source efforts, be it from microsoft or others.
*) or at least the majority of those who would improve and develop 3d printing.
@bearer said in Windows 10 3D printing support:
yes, that's why I replaced electronics on my TT printers but it's good to know, also I don't see simplify3d losing sales and slowing down (even while they are not pushing new releases and are basically at same place they were 3-4 years ago while free slicers moved ahead big time) ... also, looks like we are all guessing too much, do we know it is closed source? anyone did any research? I started here on the forum, learned ziltch
so I'll move forward till I satisfy my curriosity .. it's maybe classic M$ crap but maybe... who knows .. as I said prusa is supporting them, I doubt they paid some money to them so most probably they just read the proper documentation and got informed
@Danal said in Windows 10 3D printing support:
I could not care about web a tiny bit .. it is easier to do intial config with nice interface and nice screen and similar stuff but I'm old enough to remember programming machines with switches so while "easier" setup is welcome it's not a crucial part of the process as is done once per machine... on the other hand using the machine I want to send my g-code to gcodestat and I want gcodestat to upload that code "wherever" and start the print ... the reason for octoprint on my machines is
- to be able to shoot the gcode there trough gcodestat or directly from slicer
- to have automation (inform me trough telegram that it failed or finished, monitor the print with thespagethi plugin and inform me trough telegram about potential issue and allow me to cancel print remotely, upload the timelapse to a server, track usage, electricity, filament... etc etc etc.. )
as for shooting gcode to duet gcodestat does not support it, if there is api to upload g-code from network I'm sure they will add the feature if asked, but I looked trough some duet documentation and I did not find any api for that (was meaning to create topic about that)
and with regards to automation, I see it is totally impossible now with duet but I see that new version will have possibility to write plugins so we'll see
looking at the web while printer is working is not something I care to do.. I don't remember last time I looked at octoprint web interface and it works 24/7 on numerous printers here so no, the web interface of duet, while useful, is far from universal solution and is 100000% irrelevant to the question of how windows 10 printer support works...
what I hope/assume is how I'd made it myself (of course I didn't nor anyone give a .. ) is that there's open interface / api trough which one can on one side
- request hw info about printer / capabilities
- request current state about printer (position, temperatures...)
- can send mesh to be printed
and on other side - register "driver"
where a "driver" behaves like your 2d printer driver, you can just click print and it will slice and print with default options or it will open a "slicer" where you decide on details and then let it print...
now how the "print" actually works don't have to be any different than any of the curent methods, some printers will have to be on the usb and receive g-code stream, some will be on usb but will receive a g-code file (or a proprietary format file in case of closed source printers) or the g-code or proprietary file will be sent trough network or ..
so what I'd do is just a open api that allow apps to interact between themselves and the user, there's zero reason to limit that to streaming g-code trough usb
now, yes, we are talking about M$, maybe it is only streaming g-code trough usb but I try to keep my mind open for that to actually be something useful
May I respectfully correct some assumptions in your post above?
- it is easier to do intial config with nice interface
Actually, initial config is not available through the web interface. Initial config is a seperate tool that builds a configuration file as a "starter", then a bit of adjustment is expected to fine tune.
The web interface is designed to operate the printer. Not configure it.
- and with regards to automation, I see it is totally impossible
Many people have written to the API (see next post) and automated lots of things.
- looking at the web while printer is working is not something I care to do
I assume you look at something? A front panel? Something? When you need to interact with the printer?
Duet based printers don't have front panels (unless you add one). The web interface is the only way to interact with the printer (again, unless you add something).- numerous printers here
One of the many things created by 3rd parties for Duet is a "one pane of glass" monitor for print farm operators.
API exists. Documented here: https://github.com/chrishamm/DuetWebControl/tree/legacy
MANY people, including me, have written monitors, alternate interfaces, etc. Including "one pane of glass" monitoring of print farms. There are plugins to direct upload to Duet from numerous slicers, and writing a new one mostly involves understanding the slicer.
Automation of a Duet is very possible. As mentioned above, numerous people have done it. Same API. Many, if not all, of your bullet points are available. EXCEPT, the windows "Driver". Perhaps, given your interest level, and the well documented interface to the Duet, you'd be interested in creating that?
found the api for upload
here the /rr_upload works great ..
gcodestat is super simple little app that calculates the time to print but I fear bit more than upload to duet is required there as it currently calculates times based on smoothieware code (acceleration and junction deviation instead acceleration and jerk) so to have it calculate properly time for duet it would require bit more stuff there... anyhow even as is it gives way more accurate timing info than simplify3d/cura/slic3r do
i understand that with api it's possible to use external apps to talk to the duet but that just proves my point that "web interface" is far from "the one and only interface"
as for the windows support, as I said, I'm just, for now, curious how the darn thing works / how it m$ intended to be used and if there's anything usable in that work they did... so since I started migrating to duet (one of the printers is now having duet board, not yet operational but soon) and duet is most advanced electronics I have (klipper is in the run, smothieware old is far behind, smoothieware new is "in dev stage" for ages now so I gave up on it, replicape/revolve I have in drawer but have not tested yet ... so I'd say attm duet is def the most advanced one I have setup in a printer) ... not a big deal, I'll just look further till I satisfy my curiosity and if I find that it is useful for me I will, of course, write some code for it
Um... the API is HTTP requests. Literally a "web" interface.
And I believe my point was about "upload then print" vs. "USB Streaming". I'm not really sure how we got into such a serious disconnect over "web".
So let's set "the web interface" aside. It's really about USB. And, a look at MSDN documentation makes it very clear that Win 10 3D printer support is USB only.
Ah, we use and look at things very very very different, so just for clarification, nothing else:
You obviously look at "inital config" as making the set of files in sys directory, I on the other hand look at "initial config" as bringing printer to the state I do not care to look at it any more
I don't look at it, most of my printers don't have a panel, and while nice, I'd probbly remove the panel from this ender5 I put duet in.
my interaction with a printer is telegram notification print is done so I go take the print out of the printer, or telegram notification from TSD that some #%$^# happened and I need to remove the garbage from the printer and figure out what happened + restart print... the "monitoring" of the "printer" is not something I do after the initial config is done.. do you look at your laser printer lcd / web interface while printing or you just go by retrieve printouts and interact only when you get email that toner is out?
I didn't find msdn doc about 3d print support, that's what I'm looking for, please link me
https://docs.microsoft.com/en-us/windows-hardware/drivers/3dprint/
That just a landing page, see left nav.
Actually I believe we are saying the same thing. I very rarely look at the panel (or web) of a printer when it is "just printing". Maybe occasionally to see an estimated end time. That's about it.
How do you load a different filament? Do you ever have to jog the carriage to remove that garbage? Or heat (or cool) a hot end to replace a nozzle? Or wish to home and move around some after replacing a broken belt?
thanks for the link
my duckduckgo-fu is baaaaaaaaaaaad these days ... looks like gray hair is not the only thing that gone crazy
the "toner change" operation
"open" the extruder, shove the filament in, "close" the extruder, before the first print I just let it extrude 50mm and that's it.. these flex3drive extruders (the old ones, I have not tried G5 yet) are pretty sturdy and reliable I don't worry about them much
... also printbite is so reliable I don't even need to watch the first layer as I had to while back
the 2.6-5kg spools last a while so not something I do often
and most are single extruder..
nope, printer off, I move stuff around with hand... I jog a lot during initial setup, I can't remember last time I jogged a printer that's bin setup and operational. I jog my cnc machine "a lot" so there I find my linuxcnc touch screen super useful
nope, I service nozzles in a whole different house to where printers are
where I have all the electronics gear setup (and heaters, psu's etc..)
to replace broken belt you turn the machine off and you can move stuff around
after you replace broken belt machine need to be setup from scratch (don't really but I normally when that happens replace all belts, idlers, check all connectors, cables, replace heaters... basically service the whole machine so the whole machine needs to be squared and leveled from scratch) so for that initial setup some type of terminal/screen/jog is super useful .. usually a laptop with connection to octoprint is what I use but we'll see how it will be with the duet .. looks more promising than smoothieware+octoprint for nowanyhow, off to read that msn docs to see what's this all about
... I just hope it's not as bad as ....
Do they publish sales numbers? Or can we assume the level of innovation they're doing is proportional to sales? All I know is their DRM caused one techie to target their sales by releasing the the crack he wrote to allow himself to use the software according to the license terms; and innovation seemingly stagnated.
https://www.reddit.com/r/3Dprinting/comments/4j1l9u/dont_buy_simplify3d_until_they_relax_their/@smece said in Windows 10 3D printing support:
Prusa tends to make things open source, why not have a look at their code?
In any case I think Danal said it all
@bearer, I assume their sales is going good since they are not doing anything to improve the product (quite contrary, they are happy to censure forum behave rather "looking us from the high position") ... I guess if they had issues they would change ..
was planning to look at prusa source as last resort as I was trying to find a documentation from m$ or chewed up version of the whole thing as a blog post / forum post by someone and since now I have documentation from m$ I'm learning directly from the horses mouth .. does not look totally useless (looks like m$ is even providing their own slicer) but also does not look like it's worth an effort
