    Overriding Offsets
    • Edumaundefined
      Eduma
      Is there a way to manually enter new tool offsets via terminal to override the config file and have them retained after power cycle or estop?
      • Danalundefined
        Danal
        Manually enter: Yes, G10 in "console".
        Retain past power cycle: Edit config.g, insert same G10.
        Best of both: Write a macro called "Toffset.g" (or whatever). When you want to change, edit that file on the macro page, and then run it.
        Make it persistent with this in config.g:
        M98  P"/macros/Toffsets.g"                  ; Set tool offsets from the bed. In separate file so test macro can invoke.
        And, just for completeness, the Toffsets.g file itself:
        G10  P0 Z-2.75 X0     Y0
        G10  P1 Z-3.05 X-1.00 Y0.30
        • Edumaundefined
          Eduma
          Thank you Danal, the macro approach my work.
