    Always have to baby step
    • oryharaundefined
      oryhara
      I'm sure there is a simple answer to this question, and I did try to find it before just posting here, but I could not discern the answer from the documentation.
      I have a smart effector, and no matter how many times I run G32 and G29, my hotend won't extrude unless i babystep it up in Z about .400mm I can look and see its really squished down on the bed and obviously no filament will come out until it comes up.
      What configuration should I change to make it babystep up after auto-bed calibration?
      or do I need to tell it that the bed probe is .4 below true Z = 0?
      Or do I need to tell my slicer to print the first layer at .4 Z-height?
      thank you.
      blog: https://deltahedron.net
      • Vetiundefined
        Veti
        see
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
        Section: Calibrate the Z probe trigger height
        • oryharaundefined
          oryhara
          ah thank you very much. I don't know how I missed that before.
