    PT-100 temperature constantly at 2000 degrees after failure
    54
    7.9k
    • CoolM8undefined
      CoolM8
      The strange thing is that it used to work before until it failed in the beginning of a print. Since then i only fiddled around with the M305 P1 command.
      [[language]]
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Wed Apr 19 2017 22:18:05 GMT+0200 (W. Europe Daylight Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X205 Y205 Z205 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S1 ; Define active high microswitches
      M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
      G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
      M557 X15:190 Y15:190 S20 ; Define mesh grid
      M350 X16 Y16 Z8 E16 I0 ; Configure microstepping without interpolation
      M92 X157.4804 Y157.4804 Z533.3333 E832 ; Set steps per mm
      M566 X1200 Y1200 Z480 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X8100 Y8100 Z1200 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X1100 Y1100 Z1100 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S310 ; Set maximum heater temperature to 310C
      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P0 T10000 B3988 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 0
      M305 P1 X200
      M563 P0 D0 H1 ; Define tool 0
      M550 PUltimaker ; Set machine name
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
        Something to try. Go to the GCode console in DWC and send M305 P1 X0 followed by M305 P1 X200. If it can't communicate with the chip on the daughter board, it should return an error message within a few seconds. Repeat for channel 201. If you get no errors, you can test whether the error reporting is working by trying a channel you don't have such as 202 or 203.
        • deckingmanundefined
          deckingman
          Taking a step back and reading through this thread, it seems that it was all working fine then suddenly failed. Since then, you've tried a different sensor, a new daughter board and a new duet board. So how about the actual wires that link the sensor to the daughter board? That's the only thing I can think of that you haven't explicitly said has been replaced.
          • CoolM8undefined
            CoolM8
            Yes the error reporting is working and i get no error when calling M305 P1 X0 and M305 P1 X200 or X201 right after that. I've tried that before.
            Can I somehow debug the firmware? Maybe there i can find out what the issue is.
              I really don't think it's a firmware issue, because other people (including me) are using PT100 sensors without this problem. Some users see temperature spikes to 2000C, caused by interference. That's why I would really like to know how your board behaves with just the 2 links and a 100 to 180 ohm resistor connected to the terminals.
              • CoolM8undefined
                CoolM8
                Ok I'm going to get a resistor next week , but I don't expect to see any difference. As i said before, i can already make sure that the resistance between 2 and 3 is of around 180 ohm and the resistance between 1 and 4 is 180 ohm as well.
                How can i check if the daughter-board is actually doing anything?
                As the UI shows 2000° even when no daughter-board is connected at all, I think the issue must be somewhere there. I just don't get it why it i the exactly the same with the new hardware.
                  The UI will show 2000C whenever a temperature reading can't be obtained after several attempts for any reason. The difference is that when you send the M305 P1 X200 command, you get an error message if no daughter board is connected. You are not getting that error message, which means that the firmware is communicating with the daughter board.
                  Perhaps we should include a 100 ohm resistor with the daughter boards, to help diagnose this sort of problem.
                  • CoolM8undefined
                    CoolM8
                    Well, all this because of almost nothing! Things like that always result in the smallest possible issue.
                    First of all I got a E3D cartridge thermistor instead of a PT100 and the second i ordered was the V6 fixing kit with contains the cartridge thermistor as well. The biggest problem is that they look exactly the the same.
                    The test with a 150 ohm resistor worked and gave me a result of around 130° instead of 2000°. So I ordered a real PT100 sensor and right now I'm printing all fine with the thermistor in place (logically without the daughter-board in use).
                    Thanks for all that support.
                      I'm glad you solved it.
                      • DjDemonDundefined
                        DjDemonD
                        Thought this might be the thread to ask.
                        I got a daughterboard from T3P3 this morning (ordered yesterday so impressed).
                        I solder-bridged the pads on RTD1 carefully. I have attached my e3d pt100 (which reads 111ohms at room temp - 30 deg C!) to pins 2 and 3 on the screw terminal.
                        I added M305 P2 X200 to config.g
                        and M563 P99 H2 to tool definitions (planning to use this as chamber temp monitor until I get a heater block which can accept the sensor).
                        But no dice… 2000 deg C showing.
                        I've checked the daughterboard is properly located over the SPI pins with the bulk of the board facing in.
                        I've been into console and sent M305 P2 X0 - okay
                        then M305 P99 X200
                        "Error: failed to initialise RTD: bad response from sensor"
                        Any ideas?
                        www.precisionpiezo.co.uk
                        • Dougal1957undefined
                          Dougal1957
                          Try a lower number for the P parameter not sute but pretty certain the Firmware won't know about sensors numbered that high.
                          Sure David will be along soon to confirm or deny my assumption?
                          Doug
                          • DjDemonDundefined
                            DjDemonD
                            I'll try that sure maybe it should have been p2 or it could be something else on this board that's not quite right, but spi must work or a whole load of things would be dead which are working fine.
                              deckingman
                              Simon,
                              I'm using pt100s via the daughter board for my hot end and bed. The first channel on the daughter board is X200 and the second is X201 and P is the heater number.
                              So what you need is M305 Pnnn X200 (or X201) where Pnnn is the heater number (not the tool number). In my case I have M305 P0 X200 for the bed, and M305 P1 X201 for the hot end.
                              HTH
                              • DjDemonDundefined
                                DjDemonD
                                Thanks guys. Okay so I tried M305 P2 X200 (and 201,202,203) but still Error: Failed to inialise RTD, bad response from sensor.
                                I will rule out the pt100 board being at fault by sticking it onto my other machine and seeing if I can initialise it.
                                • DjDemonDundefined
                                  DjDemonD
                                  Okay so it works fine and reads fine on my other machine, it must be this slightly iffy duetwifi board. I won't waste any more of your time. Thank you gentlemen. Enjoy your evenings.
                                  CalvinX looks like its back to the fridge thermometer for me 🙂
                                  • TwoToneundefined
                                    TwoTone
                                    I’m having the same issue- installed new pt100 and board and it sits at 2000.
                                    I get 104 ohms for resistance of the PT100
                                    2.02 volts between 1-4 on daughter board
                                    Config file line: M305 P1 X200
                                    Sent M305 P1 X0 followed by M305 P1 X200- no errors. No errors for channel X201 and I did get error for 202.
                                    I’m using wire from a cat5 cable, so each pair has a slight twist to them.
                                    They are running within a single lose bundle from the hotend to center of top of printer and down a tower leg alone.
                                      @DjDemonD:
                                      Do you have anything else connected to the SPI bus on that Duet, for example a PanelDue connected via a ribbon cable to CONN_SD ?
                                      • DjDemonDundefined
                                        DjDemonD
                                        In my case the issue was with poor quality crimping on the original e3d pt100 sensor and not an iffy duetwifi board please consider that a retraction.
                                        I now stock pt100s without connectors with 95cm leads for less chance of a bad connection. See my signature below.
                                          @TwoTone:
                                          2.02V is too much. Assuming you are using a 2 wire connection, you should have the 2 jumpers fitted, in which case you should measure the same voltage between terminals 2-3 on the daughter board as between 1-4.
                                          • TwoToneundefined
                                            TwoTone
                                            @dc42:
                                            @TwoTone:
                                            Sorry was posting from memory.
                                            Actually using 4 wire and only see .0009 v across the terminals
