stepper artefacts
Hi my question is, i have a machine based on nema 23 and i control them with drivers connected to expansion header. when the printer drives a circle then the noise of the steppers will be louder ( when two or more axies will be work at the same time). is it possible that the cpu timing is to slow for 7 external drivers (not on duex 5)?
it will be nice if someone can help me !
PS the T parameter in M569 is correct ! (2.5)
Instant speed setting can have a significant effect on noise when the machines traverse arcs.
Motion section of the config? Acceleration, steps per mm, max speed, instant speed,etc?
thank you first for answering but this is not the problem. there is no hard acceleration and not much jerk at that movement, it looks like that all axies are cut some signals at every movement at the same time inc. the extrusion stepper.
the movement looks like doing one section-stop-doing a section-stop untill the rounded corner is done?
Run M122 and check the Hiccup count to see whether the problem is that steps can't be generated fast enough. Unfortunately, for external drivers extra delays need to be inserted (controlled by the T parameter), which reduces the maximum step rate.
It's better to choose the Nema 23 motors carefully so that they can be driven directly by the Duet.
@dc42 said in stepper artefacts:
There is th M122
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0beta12 running on Duet Ethernet 1.02 or later
Board ID: 08DGM-9T6BU-FG3SN-6JKDL-3SJ6S-18WZH
Used output buffers: 1 of 24 (18 max)
Static ram: 25812
Dynamic ram: 98280 of which 32 recycled
Exception stack ram used: 508
Never used ram: 6440
Tasks: NETWORK(ready,764) HEAT(blocked,1240) MAIN(running,3688) IDLE(ready,200)
Owned mutexes:
Last reset 00:04:16 ago, cause: software
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6440 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 9
MCU temperature: min 33.1, current 35.6, max 35.6
Supply voltage: min 24.7, current 25.0, max 25.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, SG min/max 0/634
Driver 1: standstill, SG min/max 0/682
Driver 2: standstill, SG min/max 0/574
Driver 3: standstill, SG min/max 0/698
Date/time: 2019-11-17 13:07:29
Cache data hit count 498546332
Slowest loop: 52.27ms; fastest: 0.08ms
Hiccups: 0, FreeDm: 166, MinFreeDm: 111, MaxWait: 10882ms
=== MainDDARing ===
Scheduled moves: 817, completed moves: 814, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Heater 1 is on, I-accum = 0.0
Segments left: 1
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is doing "G1 X132.047 Y743.896 E9.7239" in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 35.77ms; fastest: 0.01ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8
Interface state 5, link 100Mbps full duplex
You need to run M122 after you have done some moves and had the problem.
