    Change baby step value
    babystepping duet web control
    • Lakkoundefined
      Lakko
      i want to know if is it possible to change the 0.05mm value of the default baby step to another value.
      My printer has a magic number of 0.02mm so if i baby step with 0.05 my Z motor aren't in a full step position.
      I already know that i can use M290 S0.02 on Gcode console but is not fast as using the button on the DuetWebServer.
      thanks in advance
        droftarts administrators
        I can't see any obvious way to change the baby-stepping amount short of recompiling the firmware. This is where G290 is defined in the firmware, though I can't actually see where the 0.02mm comes from. Can anyone better at coding spot it?!
        However, as discussed in your other thread, this is only an issue because you're using full stepping. Better to use standard 16x microstepping.
        • tooundefined
          too
          If I am not mistaking, you can change the babystepping amount in Settings>User Interface.
          Cartesian Duet3+Raspberry pi 4 with 5x 1XD using servo drives printing mortars and concrete
          Phaedruxundefined 1 Reply Last reply Reply Quote 2
            Phaedrux Moderator @too
            @too said in Change baby step value:
            I think you might even be able to right click on the button a pick a new value. Same with the other axis jog buttons in DWC.
            droftartsundefined 1 Reply Last reply Reply Quote 2
            • tooundefined
              too
              Nope, that seems to work only for the machine control workspace.
                droftarts administrators @Phaedrux
                @Phaedrux said in Change baby step value:
                I did not know that! Works on the jog buttons, but doesn't work for babystepping for me (DWC 2.0.4).
                Ah, found it, you can change it in Settings > Machine-Specific > Machine-Specific > Babystep amount.
                • Lakkoundefined
                  Lakko
                  thanks a lot!!!
                  i learned something new!
