    Large Volume Printer - The Beast
    My Duet controlled machine
    • ajlappundefined
      ajlapp
      So far so good...finally got my large volume printer up and running.
      -Duet Control board
      -4 independent z-axis screws
      -THK style linear rails
      -matched axis...all 7 use the same BLDC servo and actuator components
      -Heated bed
      -1m^3 total print volume
      We still need some additional thermal controls before we can start the long prints.
      https://youtu.be/3mU3PSDIsVk
      • JRDMundefined
        JRDM
        Why BLDCs on the Z?
        ajlappundefined 1 Reply Last reply Reply Quote 0
        • ajlappundefined
          ajlapp @JRDM
          @JRDM I built all axis identical. Same screw, same bearing blocks, same rail and same motor.
          This was partially out of economy of scale and simplicity.
          I wanted to keep all the motor mounts/bearing blocks identical. These same machined blocks set the frame rails...everything is machined and pinned.
          The beefy motors paid off in the end...the table weight really swelled as the build progressed. It was stiff enough to start and the stiffening structure got heavy on accident.
          We eventually added counter-balance weights...you can see the strings and pulley assemblies at the corners.
          Anyway, the table needs to be re-imagined to cut weight.
          My only other regret was building it so tall. We wanted to fit the control cabinets underneath. But now it’s too tall to see the bed at the start of the print.
          All of the linear motion components and servos were sourced from Amazon...approx. $800 per actuator.
          JRDMundefined 1 Reply Last reply Reply Quote 0
          • Danalundefined
            Danal
            Very cool project. Glad to see somebody using true servo control.
            Keep us posted!
            • JRDMundefined
              JRDM @ajlapp
              @ajlapp What servos did you choose?
              • zaptaundefined
                zapta
                Very nice design, and choosing direct drive rather than Bowden is a good move from my experience.
                What did you use for the frame? Doesn't look like standard aluminum extrusions.
                Why so large? What object sizes do you plan to print?
                Also, what nozzle size do you plan to use for large prints?
                • ajlappundefined
                  ajlapp
                  Servos
                  https://www.ebay.com/itm/180W-Brushless-DC-Servo-Motor-Dirve-Kit-6-7A-36VDC-0-57NM-Square-Flange-ACS806/112014849053
                  Linear Rails
                  https://www.amazon.com/gp/aw/d/B06VVXT19J?psc=1&ref=ppx_pop_mob_b_asin_title
                  Ball Screw
                  https://www.amazon.com/gp/aw/d/B01LXZTNRY?psc=1&ref=ppx_pop_mob_b_asin_title
                  The frame is thick wall steel square tubing with a pad welded to one face. That face was machined flat with the bearing blocks mounts and other features all in one shot.
                  I’m using a E3D Volcan with a 1.2mm nozzle and 3mm PLA for now.
                  We had a project planned for this that has since dried up so for now we’ll just be using it as a general printer.
