    more bltouch issues....
    354
    • jaurandundefined
      jaurand
      Back for more help on the BLTouch
      BLTouch will not power on when printer is turned on, only with disconnecting the wire harness and reinserting the harness on the BLTouch will it power on, and perform self test.
      Also started getting the following error out of the blue, after many successful prints
      Error: Z probe already triggered before probing move started
      Look at the web interface and I see that Z-Probe is triggered and showing 1000.
      BLTouch light is solid red, and running the alarm release macro does not disengage the sensor.
      Firmwares:
      Firmware Version: 2.04RC3 (2019-10-08b3)
      WiFi Server Version: 1.23
      Web Interface Version: 1.22.6
      Config:
      M575 P1 B38400 S1 ; Baudrate for Paneldue 38400
      M667 S1 ; Select CoreXY mode
      M550 P"My Printer" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S1 ; X-Axis Drive 0 goes backwards
      M569 P1 S1 ; Y-Axis Drive 1 goes backwards
      M569 P2 S0 ; Z-Axis Drive 2 goes forwards
      M569 P3 S0 ; Extruder Drive 3 goes backwards
      M92 X81 Y81 Z404 E415 ; Set steps per mm
      M566 X600.00 Y600.00 Z100.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X1430.00 Y1430.00 Z1430.00 E1440 I35 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X330 Y330 Z415 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low and disabled endstops
      M574 Z1 S2 ; Define Z to use Probe. Home to Min
      M558 P9 Z1 H5 F100 T2000 ; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed moves
      G31 X-23 Y-2 Z2.745 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
      ;MeshGrid
      M557 X50:300 Y50:300 S75 ; Define mesh grid
      M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M307 H1 A306.6 C114.2 D3.6 V23.8 S1 B0
      M570 H1 P10 T15 S15 ; Configure heater fault detection (H# heater number, P time in seconds for anomaly to persist, T temp
      excursion setpoint, S time in mins before print cancelled)
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      • Vetiundefined
        Veti
        please update to 2.04 release and retest. there was a problem with bltouch.
        B4138 is the default and almost certainly wrong for your thermistors
        also post your config overwrite.
        jaurandundefined 1 Reply Last reply Reply Quote 0
        • jaurandundefined
          jaurand @Veti
          @Veti said in more bltouch issues....:
          Currently running 2.04RC3
          I do not have a config overwrite
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @jaurand
            @jaurand said in more bltouch issues....:
            why do you have
            then?
            2.04RC3
            Please update to 2.04
            jaurandundefined 2 Replies Last reply Reply Quote 0
            • jaurandundefined
              jaurand @Veti
              why do you have
              then?
              My guess is I deleted my old config override when I made changes and just have not ran M500 anytime since then.
              • jaurandundefined
                jaurand @Veti
                Sorry I see where the new 2.04 was updated.
                Updated firmware and still same issues
                • Vetiundefined
                  Veti @jaurand
                  ok
                  next step make a new extension wire. the ones supplied with the bltouch are a common source of problems.
                  • jaurandundefined
                    jaurand @Veti
                    @Veti new wires fixed the z probe trigger issue. Now new problems is my z-offset is too much.
                    • Vetiundefined
                      Veti
                      recalibrate it.
                      • jaurandundefined
                        jaurand
                        alright after re calibrating 5 times it is now finally working. Not sure why it took that many tries as nothing different but its working now. Other than new issue that cropped up but that is in a new thread
