    Before start of print nozzle is way off from the bed
    • ScaraManundefined
      ScaraMan
      Hi guys
      I have been busy trying to fine tune my printer .
      I seem to have a slight problem when beginning a print job.
      When i send a print , i have added a start and end code to home axes, start bed and heater temps, etc. etc.
      when it begins printing, it starts off like 5mm and more above the heatbed.
      i stop the print, cancel job, reload the same gcode file, run it, and then prints at the right height and everyting is correct.
      i am not using a config override file, so it cannot be that which is creating this issue.
      Does anyone have an idea why this is ?
      • fcwiltundefined
        fcwilt
        In cases like this you should post the relevant files like your config file, your homing files and the print start code you mentioned.
