DLP resin printer.
Hi I have a MoonRay S resin printer that I have had for some time now can anyone recommend a replacement board to be able to take full control of the machine as the software for printer limits its usability.
see
https://duet3d.dozuki.com/Wiki/Configuring_RepRapFirmware_for_a_DLP_printer_controlled_by_nanoDLP
@Veti thanks will look into that!
To be honest, using a Duet as the motion controller in a DLP printer controlled by a Raspberry Pi is way overkill, because the Duet provides far more facilities than is needed (e.g. the network interface). But it does work.
We have one of those machines sitting at the makerspace right now. I'll be interested to hear whether you manage to make it work. People at the space are talking about using Chitubox for slicing/controlling the printer, once we replace the controller board.
@mrehorstdmd have a look at nanoDLP and the nanoDLP shield. else, plain Jane RAMPS 1.4 will do fine.
Will do, thanks!
Thanks for the info
