    Information difference between DWC and 12864 display
    My Duet controlled machine
    • PaulHewundefined
      PaulHew
      I have modified the menu files for the 12864 display on my Ender3 running a Maestro board.
      I added the % complete to the display as well as the remaining time.
      The current print is displaying 75.2% in DWC and 72.6% on the 12864 display.
      'File progress' seems to tally with the 12864 display
      Have I done something wrong in my menu config or is it an issue with the firmware.
      Board: Duet Maestro 1.0
      Firmware: RepRapFirmware for Duet 2 Maestro 2.04 (2019-11-01b1
      It is not a show stopper! 🙂
      Regards
      Paul
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
      • PaulHewundefined
        PaulHew
        It seems to 3.3 - 3.4% out
          The 12864 % complete figure is based on file progress, because it is the only estimate that can be guaranteed to give a sensible (if not always accurate) answer, for all types of print and CNC job. I think DWC uses a more complicated algorithm to decide which estimate to display. It may be the estimate based on filament usage, because that is usually the most accurate one when it is available.
          • PaulHewundefined
            PaulHew
            Thanks for the Reply David.
            I was thinking that whatever DWC was displaying would be the same on the 12864.
            As I said, it is not a show stopper.
            BTW as it gets near to the end of the print, the % difference has reduced. 90.7 DWC to 89.2 12864
            Thanks again.
            Paul.
              dc42 administrators @PaulHew
              @PaulHew said in Information difference between DWC and 12864 display:
              This is expected, because as you get close to the end of the print, all the estimates converge towards 100%, unless the firmware has mis-read the filament usage of number of layers in the model.
