Strange X and Y homing (axis that shouldn't move, move)
  • Hi, having a problem with the X and Y homing.
    First the code:
    ; generated by RepRapFirmware Configuration Tool v2.1.3 on Thu Nov 28 2019 16:04:13 GMT+0000 (Hora padrão da Europa Ocidental)
    M550 P"AA 300x300x600" ; set printer name
    M667 S1 ; select CoreXY mode
    M551 P"AA" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M92 X80.00 Y80.00 Z4000.00 E92.60 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X1750 Y1750 Z1750 E1750 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X0 Y15 Z0 S1 ; set axis minima
    M208 X290 Y295 Z585 S0 ; set axis maxima
    M574 X1 Y1 S0 ; set active low and disabled endstops
    M574 Z1 S2 ; set endstops controlled by probe
    M307 H4 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
    M558 P9 H0.5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X25 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X20:270 Y20:275 S20 ; define mesh grid
    M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
    M143 H0 S110 ; set temperature limit for heater 0 to 110C
    M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 S"Extr 1" D0 H1 F0 ; define tool 0
    T0 ; select first tool
    Problem, when X axis is going back a few mm, the Y axis also moves slightly in the positive direction and it shouldn’t, there is nothing in the code telling y axis to move!
    Homing the Y axis is even weirder. It homes the first time but it doesn’t move back for a second passage, besides that, when it hits the Y endstop the X axis moves a little bit to the positive direction.
    But when I use the dashboard to move the axis they move as expected, only in the reight direction and only the specified axis.
    ; homex.g
    ; called to home the X axis
    G91 ; relative positioning
    G1 H2 Z0.5 F6000 ; lift Z relative to current position
    G1 H1 X-295 F1800 ; move quickly to X axis endstop and stop there (first pass)
    G1 H2 X5 F6000 ; go back a few mm
    G1 H1 X-295 F360 ; move slowly to X axis endstop once more (second pass)
    G1 H2 Z-0.5 F6000 ; lower Z again
    G90 ; absolute positioning
    ; homey.g
    ; called to home the Y axis
    G1 H1 Y-315 F1800 ; move quickly to Y axis endstop and stop there (first pass)
    G1 H2 Y5 F6000 ; go back a few mm
    G1 H1 Y-315 F360 ; move slowly to Y axis endstop once more (second pass)
    Thanks
  • @MJCT said in Strange X and Y homing (axis that shouldn't move, move):
    the H2 option is not compatible with corexy. delete the h2 part
  • Moderator
    H2 is fine for the Z axis, but for the X and Y axis it's telling it to turn a single motor, which results in diagonal movement on coreXY.
    You don't need H2 on those X and Y moves anyway since it's been homed once already. The movement to backoff the endstop can be done as normal.
  • the configurator generates this at the moment. so this should be changed. @chrishamm
  • Thanks for the help.
    The strange movements in the X and Y stopped and the Y axis goes for a second pass like it should be.
    ; homex.g
    G1 X5 F6000 ; go back a few mm
    ; homey.g
    G1 Y5 F6000 ; go back a few mm
