    Error: G30: Z probe point index out of range
    • devleonundefined
      devleon
      Hey everyone!
      I'm trying to test the accuracy between two of my z-probes for choosing the better one, and I'm trying the script from here: https://forum.duet3d.com/topic/1291/testing-resolution-accuracy-your-results-wanted-z-probe-results
      Since the thread is locked and I don't want to dig up that thread, I'm making a new one for an issue I'm having.
      When running the 36 probes 1 point script, in which I have just modified the X and Y position (see at the end), I get the following output when the script is finished:
      11/29/2019, 1:36:15 PM	M98 P"0:/macros/Testing/Z-Probe Accuracy"
      Any idea what's going on? I searched for the error message here and via google, but I found nothing. Is there another way to test z-probe accuracy?
      Info: RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Thanks!
      Code for the script:
      ;prob testing single point.
      G30 P0  X178.5 Y145.5 Z-99999 F2000
      G30 P1  X178.5 Y145.5 Z-99999 F2000
      G30 P2  X178.5 Y145.5 Z-99999 F2000
      G30 P3  X178.5 Y145.5 Z-99999 F2000
      G30 P4  X178.5 Y145.5 Z-99999 F2000
      G30 P5  X178.5 Y145.5 Z-99999 F2000
      G30 P6  X178.5 Y145.5 Z-99999 F2000
      G30 P7  X178.5 Y145.5 Z-99999 F2000
      G30 P8  X178.5 Y145.5 Z-99999 F2000
      G30 P9  X178.5 Y145.5 Z-99999 F2000
      G30 P10 X178.5 Y145.5 Z-99999 F2000
      G30 P11 X178.5 Y145.5 Z-99999 F2000
      G30 P12 X178.5 Y145.5 Z-99999 F2000
      G30 P13 X178.5 Y145.5 Z-99999 F2000
      G30 P14 X178.5 Y145.5 Z-99999 F2000
      G30 P15 X178.5 Y145.5 Z-99999 F2000
      G30 P16 X178.5 Y145.5 Z-99999 F2000
      G30 P17 X178.5 Y145.5 Z-99999 F2000
      G30 P18 X178.5 Y145.5 Z-99999 F2000
      G30 P19 X178.5 Y145.5 Z-99999 F2000
      G30 P20 X178.5 Y145.5 Z-99999 F2000
      G30 P21 X178.5 Y145.5 Z-99999 F2000
      G30 P22 X178.5 Y145.5 Z-99999 F2000
      G30 P23 X178.5 Y145.5 Z-99999 F2000
      G30 P24 X178.5 Y145.5 Z-99999 F2000
      G30 P25 X178.5 Y145.5 Z-99999 F2000
      G30 P26 X178.5 Y145.5 Z-99999 F2000
      G30 P27 X178.5 Y145.5 Z-99999 F2000
      G30 P28 X178.5 Y145.5 Z-99999 F2000
      G30 P29 X178.5 Y145.5 Z-99999 F2000
      G30 P30 X178.5 Y145.5 Z-99999 F2000
      G30 P31 X178.5 Y145.5 Z-99999 F2000
      G30 P32 X178.5 Y145.5 Z-99999 F2000
      G30 P33 X178.5 Y145.5 Z-99999 F2000
      G30 P34 X178.5 Y145.5 Z-99999 F2000
      G30 P35 X178.5 Y145.5 Z-99999 F2000 S-1
      • oliofundefined
        oliof
        It could be that a single coordinate can only be probed 32 times. So Remove runs 32 to 35 and try again (you will then get 0 to 31 which probably is more than enough. I tried with 3, 7, 15 points and didn't get a different result between the latter).
          The maximum number of G30 numbered probe points supported is 32 (P values 0 to 31).
          BTW it's useful to run tests separately with the probe points approached from the +X, -X, +Y and -Y directions, to check for certain types of backlash in the positioning system.
          • devleonundefined
            devleon
            Thanks very much for the feedback!
            I found another script on the linked github repo: https://github.com/T3P3/GcodeMacros/blob/master/Calibration and Tuning/Diagnostics/Probe_Repeatability_test
            Works fine now, got a mean deviation of around 0.00759 mm, seems good to me!
