    Maxiwatt circle heater
    543
    • matej1006undefined
      matej1006
      Hello guys,
      Do i need for this heater on my duet wifi expansion board PT100 or no?
      link to site with heaters
      https://www.hot-end.com/shop.php
        dc42 administrators @matej1006
        No, the temperature sensor in that heater is a thermistor, not a PT100.
        Dougal1957undefined 1 Reply Last reply Reply Quote 0
        • Dougal1957undefined
          Dougal1957 @dc42
          @dc42 said in Maxiwatt circle heater:
          They will also do one with a PT100 (I've just ordered one).
          matej1006undefined 2 Replies Last reply Reply Quote 0
          • Vetiundefined
            Veti
            for pt100 you will need this
            https://www.duet3d.com/PT100_DaughterBoard
              matej1006
              what is better pt100 or thermistor
              i will order soon but i need to order 4 because i building toolchanger.
              Vetiundefined 1 Reply Last reply Reply Quote 0
                matej1006 @Dougal1957
                @Dougal1957 how much is with pt100
                with thermistor is 11usd plus 15 shipping to slovenia
                  Dougal1957 @matej1006
                  @matej1006 said in Maxiwatt circle heater:
                  they charged me same price. but you have to ask them directly and they will pro forma invoice you strange thing is that shipping was more (but they do say on the website that international shipping will be amended) and the other thing is that it was done from there office in spain so I paid eu VAT at the time as well so shouldn't get stung for import taxes but we will see. If you are getting 4 the shipping will be split between them I guess.
                  • Vetiundefined
                    Veti @matej1006
                    lots of article on the web about that.
                    https://blog.wika.com/knowhow/pt100-pt1000-or-ntc-which-is-the-right-measuring-element/
                      Also https://duet3d.dozuki.com/Wiki/Temperature_sensors.
                      • deckingmanundefined
                        deckingman
                        I used to have a PT100 (4 wire) on my bed but it was always "noisy". The result of that "noise (about +_ 1 degree) the bed temperature would always be controlled at about 1.5 degrees higher than the set temperature. Changing it to an E3D cartridge thermistor cured the noise problem and bought the controlled temperature down to the set temperature. Having said that, on my Duet 3 with the same cartridge thermistor but slightly different cable routing, I had a noisy signal again. In the end I cured that by using screened cable. My take on it is that using a more accurate sensor is only valid if the signal condition is noise free.
                          matej1006
                          This post is deleted!
                            @Dougal1957 and is better then thermistor
