    Status of M37 Simulation RRF3/DSF?
    Beta Firmware
    344
    • gtj0undefined
      gtj0
      @dc42 , @chrishamm any idea when simulation will be supported? Right now it throws "Warning: M37 is not supported yet"
      • deckingmanundefined
        deckingman @gtj0
        @gtj0 That may already be fixed. At least it works for me but I'm on a beta firmware, specifically:
        RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0beta12+1 (2019-11-08b2)
        and Duet Web Control 2.0.4
        The other thing I'm doing is using stand alone mode - i.e. I'm not using the RPi. So if you are on the same firmware and DWC as me, that might be a clue for DC and Christian.
        • gtj0undefined
          gtj0
          Yeah, I always compile the latest RRF and DSF and that warning actually comes from the DSF. I'm just not sure if something needs to be implemented on the RRF side or the DSF side. Maybe they're still deciding on where the simulation should be run, on RRF as today and the results are just passed back to DSF or in the DSF itself.
            It's waiting on work in DSF.
            gtj0undefined 1 Reply Last reply Reply Quote 0
            • gtj0undefined
              gtj0 @dc42
              @dc42 said in Status of M37 Simulation RRF3/DSF?:
              Thanks David. Do you know if it's just enabling the command or is it more complex than that?
              • blt3dpundefined
                blt3dp
                Looping back around to this, looks like it's not implemented on RRF 3.0, DSF 1.2.4.0, DWC 2.07
                Is it on any of the newer unstable packages?
                My 3D Printing YouTube Channel
                Better Living Through 3D Printing
                Follow me on Instagram and Twitter
                Instagram
                Twitter
                • gtj0undefined
                  gtj0 @blt3dp
                  @blt3dp Nope.
                  • blt3dpundefined
                    blt3dp
                    Curious if anyone’s tested this on the new releases of RRF 3.0.1-RC6, DWC 2.1.1, and DSF 1.3.1
                    Instagram
                    Twitter
                    • chrishammundefined
                      chrishamm administrators @blt3dp
                      @blt3dp I have tested it and it's working, although I believe the performance could be further increased. Besides DSF does not write the print/simulation times to the G-code files yet.
                      Duet software engineer
