    Homing fails on printerbot
    740
    • nerdiatorundefined
      nerdiator
      I recently replaced my broken printerbot board with a Duet2Wifi. I'm a noob when it comes to the internal workings of this all but I think that I understand homing now. If I get it right, the goal is to move the printer to the starting point of the grid? I managed to configure my board in a way that it moves to the 0,0 mark. It moves in the correct direction but instead of stopping when the X stop and Y stop get triggered, the motors keep going and the homing fails. The LEDs on the board that indicate the X and Y stop do light off, so I think that I got it wired correctly?
        dc42 administrators @nerdiator
        Please post your config.g and homing files.
        See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_files for a description of what these files should contain, and https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches for how to test that the endstop switches are being recognised.
          nerdiator
          Here is my config.g file: https://pastebin.com/CHfyAcJV
          And these are my homing files: https://pastebin.com/MvB4A0rG
            Can you describe where on your printer the end stops are located? If you are looking at the printer from the front, the 0,0 position would be the front left corner. X- would be to the left, Y- would be towards the front.
            Have you gone through the links provided above?
              nerdiator
              This is the position where all endpoints are being triggered:
              This is the opposite position of the endpoints:
              And I've been through your links, and I do see the endpoint status switching from yes to no in the machine settings when I move the bed and extruder
                If you send M119 in the gcode console with the endstop switches not pressed, what does it reply with? And if you manually depress the switches, what does it reply with?
                  nerdiator
                  M119 without endstops pressed:
                  Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
                  M119 at endstop position:
                  Endstops - X: at min stop, Y: at max stop, Z: at min stop, Z probe: at min stop
                  • Vetiundefined
                    Veti
                    your homing files require at least firmware version 2.03
                    which one are you running?
                      nerdiator
                      I'm running on 2.0.4
                        So the Z endstop shows as activated even when it's not activated?
                        nerdiatorundefined 1 Reply Last reply Reply Quote 0
                          nerdiator @Phaedrux
                          @Phaedrux I didn#t move the Z, it's probably just still activated because it's so low. I wanted to make X and Y work first
                            Can you try modifying your homing files to remove the H2 from the second back off movements for X and Y?
                            ex: G1 H2 X5 F6000 ; go back a few mm
                              nerdiator
                              I tried that but it doesn't seem to help. I get an error saying "Insufficient axes homed"
                                Mind you I only mean the moves that have X and Y movement. The move to lift Z at the start would stay the same.
                                If you're still getting that error message after only removing the H2 from the X and Y moves it would tell me that the X and Y axis are not actually getting homed on that first pass.
                                  nerdiator
                                  Yes that's what I did. Only for the X and Y moves, but they don't get properly homed
                                    Something isn't right with your config. You indicated that the position where the X and Y homing switches get triggered is the corner of the bed marked with an X. That must be either X0 Y0 or X160 Y160. Assuming it is the bed that moves in Y and the print head that moves in X, as things stand your config says you have the X endstop at X0 and the Y endstop at Y160, which if those coordinates are where the X is, would give you mirrored prints.
                                      nerdiator @dc42
                                      @dc42 Oh I see. I just configured it until it moved to 0,0. But I probably made a mistake with the endstop location. But still, it should stop when the endpoint is triggered, right?
                                      • Vetiundefined
                                        Veti
                                        on moves that have the parameter H1.
                                        if you really have a recent firmware.
                                        are you sure that you did not swap x and y endstops?
                                        what kind of endstops are they?
                                          nerdiator @Veti
                                          @Veti They are buttons that give a 3.3V current when pressed, 0V when not pressed.
