    G29 S1 does it still work ??
    • Dr_Ju_Juundefined
      Dr_Ju_Ju
      Firmware Electronics: Duet Ethernet 1.02 or later
      Firmware Version: 2.04 (2019-11-01b1)
      Web Interface Version: 1.22.6
      Trying to build a simple macro to home all, run a 9 point bed levelling run & then display the heightmap, i.e.
      G28
      G29 S0
      G29 S1 with or without P"/sys/heightmap.csv"
      It runs ok, saves the heightmap file, but doesn't display it ??
      From machine control "Show Mesh Grid Height Map" it works, but if I enter the command in the G_Code Console it still doesn't work
      Any thoughts ???
      Julian,
      Old goat, learning new things….
        What browser?
        • fcwiltundefined
          fcwilt
          I don't know any command to show the heightmap.
          Dr_Ju_Juundefined 1 Reply Last reply Reply Quote 0
          • Dr_Ju_Juundefined
            Dr_Ju_Ju
            Firefox and Microsoft Edge, on multiple computers including Windows & Ubuntu Mate
            Julian,
            • Vetiundefined
              Veti
              i think in dwc there was a special capture in the ui that would show the heightmaps after G29.
              a macro will not trigger this behaviour.
              if you update to dwc 2.0 there is a tab now for the height map.
              • Dr_Ju_Juundefined
                Dr_Ju_Ju @fcwilt
                @fcwilt said in G29 S1 does it still work ??:
                Penny drops, yes, its probably my fault, I was hoping that the G29 S1 command would display the resultant heightmap, but sadly looks like I'm wrong (re read https://duet3d.dozuki.com/Wiki/Gcode#Section_G29_Mesh_bed_probe)
                Julian,
