    Mid-air problem with fixed bed.
    321
    • sniper23undefined
      sniper23
      I have a weird problem with Bltouch.
      G31 P25 X0 Y20 Z1.82
      I print fine on the center but when the head moves to Y130 for example, I see either mid-air print or nozzle hits the bed. Basically uneven bed problem with Bltouch even though the bed is fixed.
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Aug 27 2019 19:34:39 GMT+0300 (GMT+03:00)
      G90        ; Send absolute coordinates...
      M83        ; ...but relative extruder moves
      M665 R155 L397.19 B155 H520                                              ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0                                                            ; Put your endstop adjustments here, or let auto calibration find them
      M550 P"TEVO Little Monster"                                              ; Set machine name
      M552 S1        ; Enable network
      M586 P0 S1                                                               ; Enable HTTP
      M586 P1 S0                                                               ; Disable FTP
      M586 P2 S0                                                               ; Disable Telnet
      M569 P0 S1                                         			 ; physical drive 0 goes forwards
      M569 P1 S1                                         			 ; physical drive 1 goes forwards
      M569 P2 S1                                         			 ; physical drive 2 goes forwards
      M569 P3 S1                                        			 ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   			 ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                           			 ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z160.00 E403.00                			 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00          			 ; set maximum instantaneous speed changes (mm/min)
      M203 X36000.00 Y36000.00 Z36000.00 E1200.00        			 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z2000.00 E1000.00           			 ; set accelerations (mm/s^2)
      M906 X1700 Y1700 Z1700 E1200 I30                   			 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            			 ; Set idle timeout
      M208 Z-3.60 S1                                                           ; Set minimum Z
      M574 X2 Y2 Z2 S1                                                         ; Set active high endstops
      M307 H3 A-1 C-1 D-1                              			 ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000                              			 ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X0 Y20 Z1.82                                 			 ; set Z probe trigger value, offset and trigger height
      M557 R150 S10                                     			 ; define mesh grid
      M305 P0 T100000 B4138 R4700                                              ; Set thermistor + ADC parameters for heater 0
      M143 H0 S120                                                             ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700             				 ; set thermistor + ADC parameters for heater 1
      M143 H1 S280                                                             ; Set temperature limit for heater 1 to 280C
      M106 P0 C"Right Fan" S1 I0 F500 H-1                           		 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 C"Left Fan" S1 I0 F500 H-1                            		 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 C"Extruder Fan" S1 I0 F500 H1 T45                         	 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 S"Extruder" D0 H1 F0:1                    			 ; define tool 0
      G10 P0 X0 Y0 Z0                                   			 ; set tool 0 axis offsets
      G10 P0 R0 S0                                      			 ; set initial tool 0 active and standby temperatures to 0C
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                       ; Set voltage thresholds and actions to run on power loss
      M501        ; Load saved parameters from non-volatile memory
      ; homedelta.g
      G91                        ; relative positioning
      G1 H1 X705 Y705 Z705 F3600 ; move all towers to the high end stopping at the endstops (first pass)
      G1 H2 X-5 Y-5 Z-5 F3600    ; go down a few mm
      G1 H1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
      G1 H2 Z-5 F6000            ; move down a few mm so that the nozzle can be centred
      G90                        ; absolute positioning
      G1 X0 Y0 F6000             ; move X+Y to the centre
      ; bed.g
      ; called to perform automatic delta calibration via G32
      ; generated by RepRapFirmware Configuration Tool v2.1.2 on Wed Nov 20 2019 17:38:50 GMT+0300 (GMT+03:00)
      G28 ; home all towers
      G1 X0 Y0 Z10
      ; Probe the bed at 12 peripheral and 6 halfway points, and perform 9-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      G30 P0 X0 Y132.28 H0 Z-99999
      G30 P1 X67.08 Y116.18 H0 Z-99999
      G30 P2 X121 Y69.86 H0 Z-99999
      G30 P3 X148.59 Y0 H0 Z-99999
      G30 P4 X129.9 Y-75 H0 Z-99999
      G30 P5 X75 Y-129.9 H0 Z-99999
      G30 P6 X0 Y-150 H0 Z-99999
      G30 P7 X-75 Y-129.9 H0 Z-99999
      G30 P8 X-129.9 Y-75 H0 Z-99999
      G30 P9 X-148.59 Y0 H0 Z-99999
      G30 P10 X-121 Y69.86 H0 Z-99999
      G30 P11 X-67.08 Y116.18 H0 Z-99999
      G30 P12 X0 Y59.15 H0 Z-99999
      G30 P13 X56.09 Y32.38 H0 Z-99999
      G30 P14 X64.95 Y-37.5 H0 Z-99999
      G30 P15 X0 Y-75 H0 Z-99999
      G30 P16 X-64.95 Y-37.5 H0 Z-99999
      G30 P17 X-56.09 Y32.38 H0 Z-99999
      G30 P18 X0 Y0 H0 Z-99999 S9
      ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
      ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
      • Vetiundefined
        Veti
        post your config overwrite as well
        sniper23undefined 1 Reply Last reply Reply Quote 0
          droftarts administrators
          As this is a Delta printer, it will be because your delta settings (M665) are incorrect. Either delta radius or arm length. You should be able to fix this using delta calibration; see this guide for details: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
            jay_s_uk
            I also wouldn't use S9 at the end of the bed file.
            S6 is generally the recommended value.
            • sniper23undefined
              sniper23 @Veti
              I'm using TEVO DELTA Little Monster Printer.
              @Veti
              ; config-override.g file generated in response to M500 at 2019-12-04 17:49
              ; Delta parameters
              M665 L397.190:397.190:397.190 R155.000 H520.000 B155.0 X0.000 Y0.000 Z0.000
              M666 X0.000 Y0.000 Z0.000 A0.00 B0.00
              ; Heater model parameters
              M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
              M307 H1 A340.0 C140.0 D35 S1.00 V0.0 B0
              M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
              G10 L2 P1 X0.00 Y0.00 Z0.00
              G10 L2 P2 X0.00 Y0.00 Z0.00
              G10 L2 P3 X0.00 Y0.00 Z0.00
              G10 L2 P4 X0.00 Y0.00 Z0.00
              G10 L2 P5 X0.00 Y0.00 Z0.00
              G10 L2 P6 X0.00 Y0.00 Z0.00
              G10 L2 P7 X0.00 Y0.00 Z0.00
              G10 L2 P8 X0.00 Y0.00 Z0.00
              G10 L2 P9 X0.00 Y0.00 Z0.00
              • Vetiundefined
                Veti
                @sniper23 said in Mid-air problem with fixed bed.:
                this is a strong incidication that you never ran delta calibration and saved the values.
                • sniper23undefined
                  sniper23 @Veti
                  @Veti M665 L411.422:411.422:411.422 R161.396 H523.653 B155.0 X0.335 Y-0.197 Z0.000
                  M666 X-0.560 Y-1.026 Z1.587 A0.20 B1.00
                  still having the same issue though.
                  • sniper23undefined
                    sniper23
                    Still same.
                    • Vetiundefined
                      Veti
                      if you have effector tilt the offset of the probe could be problematic.
                      delta printer idealy want to probe with the nozzle or something very close to it.
                      have you tried with 6 factor instead of 9 as suggested by @jay_s_uk ?
                      • sniper23undefined
                        sniper23 @Veti
                        @Veti I was using 6 factors, it was the same for that. Switched to 9 factors after. My offset is 20 btw, Y offset.
