    Requested speed displayed is slower than specified in Cura
    524
    • Robundefined
      Rob
      As the title says, I have noticed that regardless of what speed I specify in Cura, it will always display the requested speed as about 10mm/s slower than what I actually specify and move accordingly. Any suggestions to correct this discrepancy?
      • Robundefined
        Rob
        I am aware of how cura breaks down the speed value, in this instance I have specified a 40mm/s speed for walls, both interior and exterior, infill, all of them are set to 40mm/s, and the web interface is showing a consistant requested speed of 30.1mm/s. The model is all walls, no infill.
        burtoogleundefined 1 Reply Last reply Reply Quote 0
        • burtoogleundefined
          burtoogle @Rob
          Please post some sample gcode that exhibits this behaviour, thanks.
          • Robundefined
            Rob
            [0_1575506420114_RollerReprapcura4.zip](Uploading 100%)
            • Robundefined
              Rob
              Oddly enough, I was tuning the current going to the stepper motors and bumping it from 500ma to 700ma on x and y seemed to have done the trick. It looks like its running at requested speeds now.
                That doesn't make a ton of sense. The requested speed should show the same regardless of what the motor current is set to.
                Was Cura configured to slow down for a minimum layer time?
                Gerrardundefined 1 Reply Last reply Reply Quote 1
                  burtoogle @Rob
                  @Rob said in Requested speed displayed is slower than specified in Cura:
                  There's no link to an uploaded file. Anyway, it sounds as if you have solved the issue so don't worry.
                  • Gerrardundefined
                    Gerrard @Phaedrux
                    @Phaedrux
                    This did it for me... Minimum time of 20 sec was too long for my part. Thanks again!
