    Have to run G code file twice to begin print at correct height
    • ScaraManundefined
      ScaraMan
      Hi guys
      I have this issue where I send the g code file to the duet wifi, and all is well until it starts to print. The nozzle tip is quite a few mm above the heatbed, I cancel, start another, then its perfect. Any clue why this is ?
      I have posted below, config, home all, home z, and a snippet from the beginning of the code file
      ; generated by RepRapFirmware Configuration Tool v2.1.3 on Wed Nov 27 2019 02:27:21 GMT-0500 (EST)
      M550 P"ALPHA 300" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P3 S0 ; physical drive 3 goes backwards
      M92 X80.00 Y80.00 Z1600.00 E311.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z300.00 E4200.00 ; set maximum speeds (mm/min)
      M906 X1050 Y1050 Z1250 E1050 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z190.19 S0 ; set axis maxima
      M574 X1 Y1 Z2 S0 ; set active low end endstops
      ;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      ;M557 X15:215 Y15:195 S20 ; define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M143 H0 S80 ; set temperature limit for heater 0 to 80C
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M143 H1 S260 ; set temperature limit for heater 1 to 260C
      M106 P0 S1 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned OFF
      M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned ON
      M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned OFF
      M563 P0 S"NOZZLE " D0 H1 F0 ; define tool 0
      ; homeall.g
      ; called to home all axes
      G91 ; relative positioning
      G1 H2 Z5 F300 ; lift Z relative to current position
      G1 H1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G1 H1 Z195.19 F300 ; move Z up stopping at the endstop
      G90 ; absolute positioning
      G92 Z190.19 ; set Z to axis minimum (you may want to adjust this)
      ;G91 ; relative positioning
      ;G1 S2 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homez.g
      ; called to home the Z axis
      G1 H1 Z195.19 F300 ; move Z up until the endstop is triggered
      G90 ; absolute positioning. added extra line could remove for testing
      G92 Z190.19 ; set Z position to axis minimum (you may want to adjust this)
      ;G1 H2 Z5 F100 ; lift Z relative to current position
      ;FLAVOR:RepRap
      ;TIME:44156
      ;Filament used: 9.62041m
      ;Layer height: 0.2
      ;Generated with Cura_SteamEngine 3.6.0
      T0
      M190 S60
      M104 S210
      M109 S210
      M82 ;absolute extrusion mode
      G90 ; Absolute Position
      G28 ; Home ALL axis
      G1 X30 Y30 Z170
      G92 E0 ; Reset extruder
      G1 X30 Y30 F4000 ;move X/Y to front of printer
      G1 Z15.0 F9000 ;move the platform to 15mm
      G4 5000
      G92 E0 ;zero the extruded length
      G1 F200 E50 ;extrude 10 mm of feed stock
      G4 10000
      G92 E0 ;zero the extruded length again
      G4 1000
      M83 ;relative extrusion mode
      G1 F1500 E-6.5
      ;LAYER_COUNT:401
      ;LAYER:0
      M107
      G0 F7500 X165.65 Y76.023 Z0.16
      ;TYPE:SKIRT
      G1 F1500 E6.5
      G1 F900 X165.918 Y75.542 E0.00552
      G1 X166.252 Y75.104 E0.00553
      G1 X166.647 Y74.72 E0.00553
      G1 X167.093 Y74.396 E0.00553
      G1 X167.581 Y74.141 E0.00552
        I would guess that it's due to homing to Z max and the homed height being set with G92 Z190 is not exactly correct?
