SOLVED Duet 3 Stepper coils pairing
I'm not sure in the documentation. What pins are the corrent pairs of coils for stepper motor?
A2+A1 (one coil) and B2+B1 (second coil)
or
A1+B1 and A2+B2?
Do I have my image drawn correctly?
Thanks for answer.
@LordOfDav11 said in Duet 3 Stepper coils pairing:
Yes, that's correct. So your diagram is correct too.
I have a running D3, with expander boards. All above is correct.
The notation using AB and 12 is confusing indeed. Had the same problem in the past.
A more intuitive notation would be for example A+,A-, B+,B-.
