    Solved Error in M502 wiki?
    • A Former User
      A Former User last edited by
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M502_Revert_stored_parameters
      This command resets all tunable parameters to their values, as set in config.g. This doesn't reset any parameters stored in the sys/config-override.g, so it must be followed with M500 if you want to do that.
      Should that be M501at the end?
      • Veti
        Veti last edited by
        no you want M500 to save the values to config-overwrite
        M501 loads the values from config-overwrite.
        If you run M502 and then M501 you would undo the changes from M502
        • A Former User
          Gotcha! Odd wording to me, but makes sense as you put it
            I agree, the wording was odd. I have just changed it; do you find the new wording clear?
            • A Former User
              Looks good 👍
