Duet Web Control update issues (2.0.4)
For more than two weeks I have been having problems with the update of the Duet Web Control (2.0.4). When I run, for example a command in Console, it does not matter. It looks, it turns, as if it wants to connect so that is well connected ... then it blocks my orders and I am forced to close my browser because refreshing does not always work. It does it with Safari and Chrome, even under Nativefier the problem is present and I have no problem with my WiFi network.
Thank you -
I’m guessing you’re using RepRapFirmware 2.05RC1. Due to a change in the way the firmware responds to commands, resolve another issue, the DWC can become unresponsive. Please either use DWC 1.22.6 with 2.05RC1, wait for 2.05RC2, or downgrade to RRF 2.04.
@droftarts said in Duet Web Control update issues (2.0.4):
Veuillez utiliser DWC 1.22.6 avec 2.05RC1
Thanks for the information...
I prefer to go again DWC 1.22.6. But I only found version 1.22.5 for download
https://github.com/chrishamm/DuetWebControl/releases?after=2.0.0-RC3
And if I go back from the DWC browser, I go back with 1.22.6, but as soon as I restart the 2.0.4 version loads again (normal, because it is on my card). Thank you
@aidar said in Duet Web Control update issues (2.0.4):
https://github.com/dc42/RepRapFirmware/releases/download/2.03/DuetWebControl-1.22.6.zip
Thank you for your link ...
Or can we find a procedure to go back definitively ... I must certainly make a mistake at one place, at each restart, I go back to version D.W.C 2.0.4!
Thank you
Well, my problem will be solved thanks to the update 2.05RC2. By the way, thank you to dc42, I think it is important to salute his permanent work!
But if possible, I would like to know how to go back.
Thank you all. -
you can open your browser directly to
http://<ip.of.printer>/reprap.htm
to go to the old version. just set a bookmark
